Basically, if you are over 6'4", here is my flow chart for bike geo selection:
-Look at Asollies chart to see where your proposed bike fits in the world of big bikes. https://public.tableau.com/profile/alexander.sollie#!/vizhome/BikeAnalysis_0/StackandReach if it's not fairly far on the right, and near or above the axis, don't bother.
-Reach must be over ~515mm. Normalize for reach. Of all the bikes you are comparing, subtract 0.4 times the stack difference from the tallest bike from the reach of the lower bikes to give you the comparable reach. In other words, if you set all the bikes up with the grips at the same height, how would the reach compare.
-If stack is low, compare it to a bike you owned to see how high you need to raise the bars.
-Check wheelbase/rearcenter ratio. Is it more than 2.9? Bad choice. Can you modify it (adjustable chaistays, steepening headangle possibly with shorter offset fork)? Is it under 2.8? Wonderful(and rare)!
-What is the claimed effective seat tube angle? What is the actual angle? If the actual angle is slack, our effective angle will be much slacker than the listed one. If so, are you willing to modify it(run an offset seatpost backwards)? Are the chainstays short? The shorter they are, the bigger the problem slack seat angles become.
-Don't exclude bikes because they aren't exactly the right type of bike. We simply don't have that luxury. In other words, if you mostly ride moderate trails, but the best fitting/geometry bike is an enduro bike, you will still be happier on that than on a poor fitting or handling trail bike. Run the suspension a bit firmer, put some faster rolling tires on. Obviously this isn't to say to buy a DH bike for XC or vice versa, just that maybe moving up or down one category is better than a compromised fit or handling.
The one exception would be for Clydesdales. Don't "underbike" especially if you shuttle or lift serve a fair bit, simply because of durability.
