Comma added. Thanks! It's a lot to edit before posting. I often later see my grammar errors, typos, and poorly chosen words. Communication is a huge challenge for me, I hope I'm improving. But I also hope the mistakes bring discussion to clarify and critique with better perspectives from others, and overall learning for everyone including me.
I'm a student of these things, not an authority. DW is an authority, a professor, a published author(ity), with patented validation of the discovery he professes. I'm not professing, I'm interpreting, seeking only peer validation and critique for my hobby of mechanical analysis and opinions. I'm a pundit at best. I've never claimed to be an authority, but I do like to encourage focused critic of concepts, such as from you and others having such interest. In this case there's a lot of concept and a complex set of variables to try to digest into a generalized and readable post that is concise and to the point without dragging in pages of pictures and calculations as an authority would do. It's just meant to give a generalized concept of the dynamics, not a proof. Proof is for authors and professors to produce. In DW's case, he can't reveal very much publicly and can only hint at the facts due to the increasing design thievery by a few "copy-cat" builders.
To calculate the Mojo anti-squat I used Linkage comparing different anti-squat rates to points in sag depth of the Mojo, and other bikes, about 6 months ago. Not long after getting my Mojo 2 years ago, I measured it and input the Mojo into Linkage and saved it to the subscribed on-line library. Linkage has mouse-pointer coordinates, and can show the distance of point-to-point during a click-and-drag. And in Linkage I can use Edit to choose a gear set, and it shows the chain line. And I can sag the suspension to a fixed static level with the slide bars in the Linkage graphics. IC and CC can be displayed for floating axle 4-bars. And by projecting lines on the screen with a straight-edge I could find the intersection of the chain-line with the axle through IC radial alignment swing-line. And by projecting a line, from the rear tire's ground patch through the chain/radial-swing line intersection, forward to cross a vertical line through the front axle, the anti-squat point at sag is found. Compare that point on the vertical line through the front axle with another point on the same line at the height of the CM and the percent of anti-squat can be calculated.
I used a rough anti-squat difference using the same 20mm measurement the fork travel was lowered for the example anti-squat alignment measurement change, it's close enough to show about 2% reduction in anti-squat rate for a generalized concept.
BTW, the "anti-squat center" I describe at the front wheel base as a virtual pivot was a new concept to me while writing that. I'll have to think about that some more. While accelerating the pedals, does the CM and frame swing as if pivoting behind that dynamically rising and falling "anti-squat center" point about the front wheelbase? It does feel like it when riding I think. And as always, the ride experience is the best test of a bike's performance.
Thanks for your comments!
