can it be used any frame that is designed for an EBB, and do you have to use set screws with it?
The OD of the EBB itself is 2.137". It can be used with set screw or pinch bolt frames as long as they have an ID of about 2.140"RockStarRacing said:can it be used any frame that is designed for an EBB, and do you have to use set screws with it?
how many licks to the center of a tootsie roll pop? but more importantly, you ever gonna do another pedal.........Brent said:Let me know if you have any other questions.
The rig is a wedge type so it will not work. I can't find any specs on the Carver so you'll have to take a look and see if it has set screws, pinch bolts, or nothing.RockStarRacing said:its to go in a rig, and a carver so no set screws, will it work and how much are they? (and what colours do they come in )
