Thanks Mtnbiker72, forgot to mention that important rule. :thumbsup: Install the cranks with some cheap shimano M8 steel crank bolts to proper torque recommendation, then back the same M8 steel crank bolts back out. Then install M8 aluminum or titanium crank bolts of your preference.mtnbiker72 said:M8 bolts as far as I know.
FYI, Al and Ti crank bolts are only used AFTER you torque your crankbolts on with steel bolts.
Yea, I removed a few broken bolts over the years from spindles after the bike owners tried putting on their crank arms with their SRP bolts...Hardguy said:Thanks Mtnbiker72, forgot to mention that important rule. :thumbsup: Install the cranks with some cheap shimano M8 steel crank bolts to proper torque recommendation, then back the same M8 steel crank bolts back out. Then install M8 aluminum or titanium crank bolts of your preference.![]()
I'm sure breakage happens a lot with the aluminum bolts. I have never used aluminum crank bolts myself. I have been using some syncros crank-o-matic titanium self extracting crank bolts for years w/o problems after I torque the cranks on with steel bolts. I only used aluminum bolts to hold my bottle cages, bike computer and my bell. Wouldn't trust them on anything else on my bike cause I value my life too much to offset the ounce or two difference in weight.mtnbiker72 said:Yea, I removed a few broken bolts over the years from spindles after the bike owners tried putting on their crank arms with their SRP bolts...
