1 - 9 of 9 Posts
Hi,
I know this is a drivetrain question (already posted there), but it's going on a One9. I Just got a Phil b/b and before I install it I want to make sure there isn't a problem. I noticed that the cups don't slide easily over the bearings. I am not able to push them all the way onto the bearings by hand, about 1/3 to 1/2 the width of the bearing . I assume when I do this with a torque wrench it will go all the way on, but I wasn't sure if this was supposed to be a close tollerance fit. I figure this is all fine but want to be sure before I install this beauty. Any help is appreciated.
Thanks,
Dan
Tight fit
Dan,
Congrats on your new frame ;-)
Phil Wood cups will have very fine tolerances so it may not press on by hand. Once you install it with a torque wrench it should go together like butter. Make sure you grease the treads well and start the cups in by hand. I have had a few PW parts and all have been jewels.
Chris
Niner Bikes
Discussion Starter · #3 ·
Niner Bikes said:
Dan,
Chris
Niner Bikes
Thanks Chris. One step closer to riding....now for that Niner fork ;-)
Dan
My Phil BB was accompanied by a tube of loctite. I just used grease, but when I do the preventive maintenance R&R I'll probably go ahead and loctite 'er down. I'd be apprehensive about gluing it in before I knew where it needed to be set at, so trial fit it and measure where the cups sit in relation to the shell, then remove and apply the glue and replace.
velocipede technician
use the loctite
grease the threads and but a few drops of loctite inside each cup where it will contact the bearings,take a couple minutes to get your chainline right and ride of into the sunset cause your bb troubles are over.id tour around the world on my phils without a second thought.
Occasionally engaged…
Phil's grease for me...
RobW said:
I used loctite as specified for years, but if I got wet the bb would start creaking. Now I use Phil's grease on the threads and I get no creaking, no movement, no pitting. YMMV
And as to the orginal question, the cups/retaining rings will push on to the bb shell when you intall it. When I pull the bb, only one of the cups/retaining rings comes off and the other is lodged on pretty tight, but that's not a problem. Works the same with both my Phil bbs...
That's what I did first time around, guess I'll do that again.
1 - 9 of 9 Posts
