1 - 1 of 1 Posts
Hello,
This is my first post on MTB but I'm on the site quite a bit.
I have a question about the bottom bracket setup on this bike. The bike was ordered directly from Devinci but it came to my lbs in a couple separate orders because they didn't have the bike in my size. So the lbs is building it up for me.
My lbs mechanic is having troubles getting the Shimano XT cranks to work with the PF30.
I have noticed on the Devinci specs it say the bb is a PF30 Adaptor.
TECHNICAL SPECIFICATIONS
FRAME
CARBON DMC-G​
FORK
FOX FLOAT 32 CTD FIT 29 100MM, KASHIMA COATING​
HEADSET
CANE CREEK 40-SERIES ZERO STACK​
TIRES
MAXXIS CROSSMARK 29X2.10 EXCEPTION SERIES HIGH TPI​
FRONT WHEEL
EASTON EA70 XCT​
REAR WHEEL
EASTON EA70 XCT​
FRONT BRAKE
SHIMANO XT M785​
REAR BRAKE
SHIMANO XT M785​
REAR DERAILLEUR
SHIMANO XT M780​
FRONT DERAILLEUR
SHIMANO XT M786​
FRONT SHIFTER
SHIMANO XT M780​
REAR SHIFTER
SHIMANO XT M780 10S​
CRANKSET
SHIMANO M785 HOLLOWTECH II 40/28T​
BOTTOM BRACKET
PF30 ADAPTOR​
CASSETTE
SHIMANO XT 10S 11-34T​
CHAIN
SHIMANO XT HG94 10S​
HANDLEBAR
TVT NOIR T30 FLAT​
STEM
TRUVATIV STYLO T30 31.8MM​
SADDLE
SELLE ITALIA SL XC​
SEATPOST
TRUVATIV NOIR T30 31.6MM​
SEAT COLLAR
ALLOY CNC 37MM​
GRIPS
DEVINCI PERFORMANCE W/LOCK-ON​
It seems weird that a bike from the factory would be using adaptors like WheelsMFG or others.
Does anyone know the proper procedure Devinci would use for this XT cranks with PF30 setup?
I can't get ahold of Devinci on the phone or email. I've tried a couple times.
Anyways, I just thought I would put it out there hoping someone or a Devinci factory mechanic might come across this and have an answer.
Thanks for any help
1 - 1 of 1 Posts
