Steevo, ok so you are the original owner. I guess we keep things in the family around here. I figured that they were once a part of an H-Bar experiment.
Rainman, funny you should mention it. I am already planning on ordering some of the chunky ESI grips after reading your recommendation in another post. I just need to do it. The skinnt Pedros grips are not big enough for my hands, nor do they provide much comfort. I looked into getting the levers closer and it looks possible. There is no pivot on the lever though. You just turn a screw which closes the lever so that it is closer. You are right, they need to be tilted more as well.
GrumpyOne, Tony has been great to deal with. He builds a mean bike, period. The steel combined with the 29 inch wheel running low tire pressure (25psi) feels so nice that I don't really miss suspension. My last bike was a Turner 5 Spot which is about as polar opposite from the Ogre as things could possibly get and still be a mountain bike.
Some thoughts after yesterday's ride:
The H-Bars are quite interesting bars. I did some quite a bit of pavement riding yesterday and it seems that with the low gearing on the SS (32x22) I am putting a lot of pressure on my hands. This is only on the flats and spinning spots where I cannot evenly distribute the weight properly on the pedals, saddle, and bars. If this were a geared machine I don't think I'd have this issue becasue it's mainly a low gearing issue. I did find that I really like them for climbing. While they do put my hands back a little further than they would be with a conventional bar, I did not find this to be a negative. The soak up vibrations better than any bar I've ever owned. The difference between the 5deg/90mm Thomson/Easton Monkey SL combo and the 15deg/140mm/H-Bar combo is VERY apparent. With as stiff as the Thomson stems are, most of the flex is coming from the H-Bar. I'd love to try them on a geared bike as well as I think they'd be great for all sorts of riding conditions...singletrack, fire roads, paved...
The Avid BB-7's feel great. I know that they are new and will probably loose some strength at time goes on. Right now I like the even feel better than the Juicy 7's. It is the first time that I've ridden with the cable accuated discs. All the other brakes I've owned were either V or hydro discs. As Rainman mentioned, I've got to adjust the levers some more to where they are more angled and closer to the bar. They are very nice feeling levers though.
I heard some pinging coming from the rear wheel while really mashing up a steep portion of paved road just up from my house. It sounded like the spokes were pinging as I hit the bottom of each pedal stroke. I've never had this happen before. Anybody have any ideas?
I've heard that the King hubs can develop some play in them, but I don't know exactly what this is.
I'm still contemplating a Reba for the front. It would just make things that much more comfortable I think. Some of the trails around here can be pretty rough in places. I'm also contmeplating a geared bike as well. I have 90% of the parts just laying around and it is a shame to have them go to waste!
Now if I could make up my mind as to whether to get a sus frame (Lenz, Ventana, Turner?) or a Ti hardtail (Black Sheep, Eriksen?). Choices!!!!!!
