i own a 2003 warrior disk. i just replaced my pedals because my stock ones were shot. There brand new and they make the same crack noiseas a shot pedal is this bad. Also its not the crank i already cheches that
Noises coming from the crank/BB/pedal area can often be hard to pinpoint. There are several different things to check out. I would recommend explaining the problem to an IBD and having them take a close look. It could be anything from a loose chainring bolt, to a bad BB or crankarm.ironhorserider said:i own a 2003 warrior disk. i just replaced my pedals because my stock ones were shot. There brand new and they make the same crack noiseas a shot pedal is this bad. Also its not the crank i already cheches that
