1 - 15 of 15 Posts
Just looking for feedback- I’ve never ridden anything but Trek and 29’er...
I just went to a 2018 SC TB 27.5...
Pedal strikes galore - I made a sag adjustment and it helped a bit ...
But ...
Do you think it’s more the tire or the brand ? Lower BB on SC I believe ...
Will a 29 tire do the trick ? I kinda like the width of the 27.5 ...
Thx
Sent from my iPhone using Tapatalk Pro
Welcome to the new geo. Hated it on my 6Fattie and sold it. Midwest rocks and roots. Riding a Stache now. Great bike.
Sent from my SM-G930V using Tapatalk
I did the same. One season on a SC 5010, sold it and bought a Stache. Loving it so far.
If you want to keep the tall boy, 29er wheels are a good idea with the biggest tires you can fit. You can also try lengthening the fork with more travel; you can buy longer air shafts for most forks for ~$30. You will raise the BB by about half the amount of travel you add. This will also slacken the head and seat angles by ~1 degree per 20mm of added travel. Shorter cranks are also an option.
Does your frame have a 'flip chip'? The 'High' option will raise the BB a bit (5mm?) and that is free!
If you still have the Trek, some interesting trivia would be for you to measure from floor to center of BB, just as a comparison to how much lower the new bike sits at the BB.
My full suspension sits 1/2" taller on 29x2.3 at the axle than the 2.8" 27.5. I haven't checked the BB heights, but I get no pedal strikes on the hard tail 27.5 because there is no suspension to sink.
I only mentioned the axle height to show the bike sits only 1/2" higher between the two wheel sizes.
I've had more pedal strikes on my full suspension in 2.5 years than I had on my 26" hard tail in 8 years. It's still not a lot of strikes, but more than I wish I had.
I am also on flat pedals (same pedal on both bikes) which I believe are thicker than clipless? Maybe I just remember the composite pedals are thicker than their aluminum counterparts.
g=9.764m/s2
Whooah man I've never heard of that before! any feedback on it?
Yea, put one on a '14 Stache rebuild with 175mm crank... not only no pedal strikes but no chainring strikes either. Niner made them to use with 27+ wheel sets and now Guerrilla Gravity includes them with their modular frame platform. Here is a blurb from GG's site ... "there are two lower cup options for the GeoAdjust Headset, a 0 mm Cup and taller 15 mm Cup. The 0 mm Cup is designed to work best with 29" front-ends and the 15 mm Cup with 27.5" front-ends
1 - 15 of 15 Posts
