Do I need any special tools for removing my pedals? and how do I remove them?
Right on gmats!gmats said:Some of them use 15mm wrench. Some require a thin 15 mm wrench. Some can be done with a 8mm allen wrench.
Right side pedal is standard thread. Righty-tighty Lefty-loosey.
Left side pedal is left hand (reversed) thread. This means "Righty-loosey" "Lefty-Tighty"
Hope that helps.
to remove pedals, i usually just have the wrench handle pointing up and turn towards the chainstay, not really sure which side is reverse thread.Gilboy said:Remember if you are using the allen wrench on the inside of the pedal; the direction is oppisite as if you were using the wrench
