I've been researching pedals for the past few days, here are the ones I'm considering:
Crankbrothers: I narrowed down my research to the Stamp 3 or Stamp 7. I like the idea of a 6061 body rather then plastic or cast aluminum. According to CB, the platform itself is the same size on both models, the Stamp 7 has more machining operations done so it is lighter and has a 1mm concave. The Stamp 3 has a slightly wider stance on the bike because the spindle is longer between the crank and the platform. I think I could get the concave feel from longer pins on the front and back of the Stamp 3 if needed. My current no name pedals are slightly convex but get some concave from the pin arrangement. Stamp 3 can be had for $80, Stamp 7 can be had for $100.
Kona Wah Wah 2 Aluminum: looks like a good choice, but the large inboard bearing would push my foot farther out, meaning the platform is effectively narrower by the width of the bearing, they list "platform measurement" on their site, so maybe they don't include that bearing housing in the width. Cost $120
Shimano XT PD-M8040: $75 each with 10 pins and a 110x115 platform. Apparently concave platform and swappable pins to add to that feeling. The downside looks to be the heavier weight and thick body.
I may end up ordering a couple different pedals from Amazon to compare them in person and just send back what I don't want.
I can add some information about the Wah Wah 2 Alloy and Stamp 7 Large. I currently have both in my possession to compare.
@BroncoAZ is correct that the Wah Wah 2 Alloy is narrower than the specified width by the width of the bearing.
I wrote a detailed, if perhaps difficult to read, post in another thread: (
https://forums.mtbr.com/showthread.php?p=14991269)
Essentially, the usable surface area on either side is 10mm less in both length and width than specified by Kona. the usable platform size is 110mm long, by 108mm wide. The 118mm is the true width when including the bearing. So the effective platform is 108mm wide, and starts 10mm outward from the crank.
The length of the pedal is also truly 120mm. But there is only 110mm on the top surface, front to back, where it angles away at the back 10mm. Of the 110mm, 60mm of this is in front of the axle center and 50mm behind.
I like that, because I have long feet and it helps with not feeling like I am always holding myself up from falling forward.
The Stamp 7, I have not tried, and plan to return so won't be trying, at least for now. However, in a side by side comparison, the platform of the Wah Wah 2 Alloy goes farther out in front of the axle, and is about the same behind the axle as the Stamp 7. Also of note, the traction pins/screws are further spread out on the Kona.
If I get a chance, I'll try to take some side-by-side pictures with some rulers and make a write-up to share.
Sent from my BBE100-5 using Tapatalk
