Has anyone thought about a sprocket mounted between the crank and the cassette? With a standard single to 3-ring crank setup, and a standard eight or nine gear cassette, what if a doubled sprocket (side by side) was mounted mid way (approximate depending on frame layout and space) to make the pedaling power from the crank displaced to the mid-gear before it goes to the cassette?
The basis for this idea is taken from a gear reducer.
Changing gears at the crank would be the same with a derailleur, and the changing of the gears at the cassette would be the same also. The only difference being the mid-gear, that is basically a "constant" that would make pedaling easier while you shift through all of the gears.
