Hi folks. I got a little wobble in my right pedal. It moves about 2 mm in and out from the crank arm. The cone bearing spins flawlessly and sits straight in place. The movement is in the lock bush, the part which screws the axle into the pedal body with a 17 mm nut. As you can see in the pic, the left pedal has a 2 mm green vasoline colored space between the cone and the lock bush, On the right one the lock bush can be moved 2 mm from its original position down to the cone. I guess that the race on the axle that holds the lock bush in place is worn out. Am I missing something? Can it be repaired without replacing the axle? I've only cruised 200 km with them. Bought on AliExpress for 50 $, so no return and a doubtful chance for refund.
Greeting from Croatia.
