The new Paul WHUB (front disc hub) has 135mm spacing for fitting forks like Jones, I understand. The center-to-rotor on a standard rear ISO 6 bolt disc hub is 52mm (I'm fairly certain) and the center-to-rotor on the WHUB is 57mm (from Paul direct).
So it looks like the chainline moves out by about 5mm. There is plenty of space to move the cog out by much more towards the stays, so I don't see an issue in the rear. I have an eccentric BB that I can nudge out a few mm, and by using a wider spindle I think I can adjust chainline out to 57mm.
Has anyone considered this or can anyone think of why this wouldn't work so well? I like the fact that this hub should make for a super stiff, but dedicated fixie, wheel.
I'm also not sure about the WHUB availability.
