There's been a group of anti-biking hikers at Kanawha State Forest, WV who recently have set traps to sabotage bikers as they ride the trails.
I came across one of their famous "bike traps" today. I was taking my dogs out for a stroll in the Forest (forced by guilt trip for leaving them at home the past 6 days). We walked up Davis Creek from the pond and at the turn-off for Teaberry we climbed up towards Shrewsbury. This section has a steep and gnarly "crash n burn" section going the opposite way and right above it is a small stream crossing. Well... I could see the fallen tree from the downihll side...
The tree was cut at a 90 degree angle off it's stump, which rested several meters uphill of the stream and there was no way it would've fallen right across the dip in the trail where the stream flows and blocked the tree between waist and chest high. It was cut at a 90 degree angle and four feet or so after it crossed the trail it was cut again at 90 degrees and propped up on the other piece of the tree (which was buried into the ground). The uphill end of the tree had obviously been placed, as a small hole the width of the tree had been dug out of the ground.
I couldn't do anything but report it when I got back to the office. I was half-tempted to go knock on the super's residence and let him know about the situation. But if it is not cleared by next weekend I most certainly will. The super is very pro-biking (he has a northshore course in his backyard). And if any of you reprobate hikers are reading this post out there... you better hope to hell I or anyone else with a two-wheel mind EVER finds out who you are or sees you destroying our trails because I, like many others, will not hesitate to accelerate your denture process... nor will my headset wrench.
