I've built mine up as a 27.5+ (Nobby Nic 2.8's on Roval Traverse Rims, 29mm internal) and have been running it that way for about six months. See post #228. I just threw the 29" wheels back on it and will ride it like that for a while, so I really won't know what I like better until I get some time on it with the new set up. The 2.8's fit just fine in the frame but the bottom bracket drop is noticeable.Does anyone try to run 27.5 + (plus) wheels-tyres?
Is it possible?
I've built mine up as a 27.5+ (Nobby Nic 2.8's on Roval Traverse Rims, 29mm internal) and have been running it that way for about six months. See post #228. I just threw the 29" wheels back on it and will ride it like that for a while, so I really won't know what I like better until I get some time on it with the new set up. The 2.8's fit just fine in the frame but the bottom bracket drop is noticeable.[/QU
Running with 29er forks , or 27.5 + boost ?
I'm running a 29er fork - X-Fusion Trace RL2. The front tire has sufficient clearance but it's close. I don't know if I could go up to a 3.0.I've built mine up as a 27.5+ (Nobby Nic 2.8's on Roval Traverse Rims, 29mm internal) and have been running it that way for about six months. See post #228. I just threw the 29" wheels back on it and will ride it like that for a while, so I really won't know what I like better until I get some time on it with the new set up. The 2.8's fit just fine in the frame but the bottom bracket drop is noticeable.[/QU
How much do you weigh? Unless youre a clyde, I think youll be OK, and probably still OK even if you are. The frame seems to be built pretty beefy with gusset plates and thick welds everywhere. Only thing that its missing is a thru axle, but thats not going to make or break it for you. At 240 lbs ride weight, Ive had mine (27.5+) off a few 2' to flat drops without any worry, though that sounds tame by comparison. Personally I think youll get tired of a hard tail before the frame gives up the ghost, but I dont have the same aggressive conditions around here, so I cant say for sure.Is anyone riding their 29ers on trails with chunk rocks, jumps, and drops? I built this up as an "all mountain" 29er. I missed the "trail" frame in the description on the web site. Im just worried about the strength of the frame with that type of terrain. I am starting to ride more aggressive trails, and I hoped this would fit right in.
How big of jumps and drops are you doing? lolIs anyone riding their 29ers on trails with chunk rocks, jumps, and drops? I built this up as an "all mountain" 29er. I missed the "trail" frame in the description on the web site. Im just worried about the strength of the frame with that type of terrain. I am starting to ride more aggressive trails, and I hoped this would fit right in.
Culvert confluence and rocky have some good jumps and drops. Rocky and flood trails are well, rocky.How big of jumps and drops are you doing? lol
