When I last talked to Calvin from Park Tool (at the recent QBP SaddleDrive event) he gave me a hint as to what new products they would be showing at Interbike. He said the new product would be, "Made for you if you have a bad back or a really heavy bike." My guess at the time was a power lift bike stand.
Bingo!
One of the main new products (out of the many on display) from Park Tool is the PRS-33 Power Lift Shop Stand. Now, a power lift shop stand is definitely not something the average consumer is going to buy. This stand was meant for shops and can lift up to 120 lbs! If your shop works on a lot of heavy DH rigs, electric bicycles or heavy cruisers...this just might be a welcome addition to keep your mechanics happy.
In this video, Eric Hawkins from Park Tool shows us some of their new tools for 2013 including the Power Lift Shop Repair Stand.
The Park Tool Power Lift features:
-Adjustable height from 6" to 78" (16cm-198cm)
-Integrated work tray
-Integrated accessory bar to hang wheels, air hoses, lights and just about any other accessory you can think of
-Electric motor able to smoothly lift 120 pounds (54kg)
-Oversized gussets to mount stand directly to the floor
-100-3D Micro Adjust clamp
Some more new tools for 2013 from Park Tool>>
MTB-3.2 Premium Rescue Tool (disc brake specific tools)
Now with more tools, an upgraded chain tool and a sleeker, smaller size. The MTB-3.2 is built to tackle nearly any road or trailside emergency repair. It's small enough to take along yet the protected tools feature enough leverage to make repairs quick and easy.
Features:
-Composite protective shell doubles as two super strong tire levers
-10-speed compatible chain tool
-Disc brake piston press
-Rotor truing tool
-1.5, 2, 2.5, 3, 4, 5, 6, & 8mm hex wrenches
-T10, T25 and T30 Torx® compatible drivers
-Straight blade screwdriver
-Philips head screwdriver
-8, 9 and 10mm box end wrenches
-Emergency pedal wrench
-Presta valve core/extension tool (4mm)
-Bottle opener
-Three spoke wrenches (0.127", 0.130" and 0.136"/SW-0, 1 and 2 sizes)
-Knife
The MTB 3.2 multi tool will be available January 2013.
CT-6.3 Folding Chain Tool with Peening Anvil (11 speed compatible)
Now 11-speed compatible, the CT-6.3 removes and install chain pins in all derailleur chain. Smooth and powerful, this handy take along is encased in a stainless steel shell, which becomes a comfortable handle when opened. Also included is a peening anvil that allows for peening of Campagnolo® 11-speed chains which pivots out of the way when not in use.
Features:
-Cast steel body with stainless steel case
-Replaceable pin (part # 985-1C)
-Loosening shelf for tight links
-Works on 5 to 11-speed derailleur chains
-Foldable peening anvil
The CT-6.3 will be available January 2013.
AWS-50 50th Anniversary Three-Way Hex Set (forged aluminum w/gold plating)
This is a limited edition version of our world famous "Y" wrench available in limited quantities and only in 2013 (Park Tool celebrates 50 years of Quality Bike Tools). The AWS-50 features a forged, two-piece aluminum body anodized in Park Tool Blue with a laser engraved logo. Hexes are made of industrial strength, heat-treated steel and gold plated to commemorate our 50th Anniversary.
The AWS-50 will be available February 2013.
For more info: www.parktool.com
