1 - 7 of 7 Posts
no problems at all. I use Stan's with yellow strip on ZTR355s and it's great. I weigh 180lbs and run between 26-29 psi. I was even able to install with a floor pump not a compressor although if available, use a compressor...it will save you time, frustration, and arm fatigue.
Bringing back an old thread here...
I'm thinking about running my Fire xc pro's tubeless on my bontrager race x lites to shave off some weight, and to avoid pinch flats. Would doing so result in a smaller maximum psi??
Right now the max is 55psi, but that's with a tube. I ride to school almost everyday and pumping up the rear to 50-55psi helps a ton with rolling resistance, so if i'll only be able to pump up to say 35psi I may just keep the tubes...
1 - 7 of 7 Posts
