:thumbsup:
I changed the color on my mukluk to candy apple red powdercoat.
orginal blue was a ***** to remove so I let the pc guy do it. prolly was pc not wet paint. left the headbadge off.
You weren't concerned about powder coating an aluminum frame? I was considering going that route but I've read that re-heating the aluminum after the factory artificial aging process could cause weakening of the frame. Have you had any issues?
I emailed Cycle Art to see if they did powder coating and this was their response:
"Aluminum frame builders use heat treatment after welding to achieve the optimum strength, rigidity and crack resistance. The process varies with alloy and its intended application. While most heat treating of aluminum occurs near 1000 degrees F, the final process is "Artificial aging" in the 200 to 350F degree range for a specified length of time and with controlled gradual cooling. Powder coating requires baking in this same temperature range with less controlled cooling. During original manufacture this is taken in to account, so powder coat baking can be final heat treatment. Refinishing presumably extends the process beyond the intended specification and adds other variables.
High quality bicycle frames are made of 6000 and 7000 series alloys. Of the many aluminum alloys, these are most affected by extended artificial aging. It's possible that very overbuilt frames of lower quality alloys are less affected.
So while some aluminum bike frames are powder coated by the factory, heating them again in a second bake cycle for refinishing is not something CyclArt will do."
