I think you are correct that it may hold up better, it is some tough $hit. But it tends to go on real thick like 1/8" or more and would probably be heavy. Also if you were going to do it yourself you would probably use the parts store spray can kind that's likely not as good as the professionally sprayed bed liner material. If you know someone who has a sandblaster give it a try, if you dont like it, blast it off. Or, buy some used black cranks and sell yours.eman said:something like a truck bed spray would hold up better.
Even anodizing wears off from shoe wear and ends up looking ugly as crap. No paint/powdercoat/etc known to man would hold up even a fraction as long as anodizing. Leave 'em silver lest you be disappointed.eman said:I want to paint my crank arms black, which are currently silver. Any ideas on what type of paint that will stick? Maybe some kind of truck bed liner spray?
Is to remove the rings and remove all of the anodizing with oven spray cleaner. I have some XTs that i did this to. I polished them up and they look great. I can polish out rub marks from my shoe. I touch them up once a month with some polish.eman said:I want to paint my crank arms black, which are currently silver. Any ideas on what type of paint that will stick? Maybe some kind of truck bed liner spray?
I thought my large black ring looks good with the polished crank and my polished frame.eman said:Quattro, thats actually a really good idea. DO you think I could also polish the chainrings or would that be bad for something.
Acutally, that is incorrect. Anodizing (which can only be done on aluminum and titanium) is a dye that impregnates the surface of the material. It is easily worn off. Powdercoating, on the other hand, is electonically fused and baked onto the material. It is the most durable of all finishes. I have a old BMX bike that I had the frame powdercoated. And it rode around in the back of a pickup truck bed for three months (don't ask...) and when I got it back, the powdercoat was dull (buffed out) but the bed of the truck had scratches from the frame.bulC said:Even anodizing wears off from shoe wear and ends up looking ugly as crap. No paint/powdercoat/etc known to man would hold up even a fraction as long as anodizing. Leave 'em silver lest you be disappointed.
Powdercoat wears off. Have seen it happen. Heck, I wore through the chrome plating on my Profile cranks.IAmCosmo said:Acutally, that is incorrect. Anodizing (which can only be done on aluminum and titanium) is a dye that impregnates the surface of the material. It is easily worn off. Powdercoating, on the other hand, is electonically fused and baked onto the material. It is the most durable of all finishes. I have a old BMX bike that I had the frame powdercoated. And it rode around in the back of a pickup truck bed for three months (don't ask...) and when I got it back, the powdercoat was dull (buffed out) but the bed of the truck had scratches from the frame.
Powdercoating will hold up to whatever kind of abuse you throw at it (if it is properly applied).
