here is what I did...
02 RS Psylo SL, coil boinger
It came black.. As I'm on a personal crusade to eliminate that friggin color from the bike world....I decided to paint.
Now that said, mine is flat primer gray grey? now. By choice. I like it.
I took off the metal decals, and took the shock apart. Be sure to remove the interior wiper seals if your shock has them. (notice I'm using the correct term shock, for the bouncy thing on the front of the bike)
Anyway I got everything off and out of the shell.
Denatured NOT isopropyl alcohol. Use denatured alcohol to remove all grease and oil. I then sanded it by hand twice, to roughen up the finish. 1st 80, then 120 grit. The idea is not to take off the present paint, but to prepare the surface for new paint. Don't go down to the metal, there's no reason.
Next, I used Krylon brand, primer flat grey paint. Maybe 3 coats total I think. Let 'em dry about an hour between coats. I got a small run on one of the legs, so I left it a day, and sanded it down on the spot, then re-sprayed. Looked perfect.
Set oven to 225 degrees. It's gonna smell, so be prepared for that.
I set the shell in the oven, middle rack, and 'baked' it for 1 hour. Much higher and you'll risk scorching the paint.
Remove from oven, cool, cut into squares, serves 4, enjoy.
Once it's cooled, you've got a fairly sturdy paint base. If yer gonna paint it custom, I'd suggest still putting on primer as a base coat, and baking that. I just like the color so I left it.
After you apply whatever color you decide, you can bake it again, try to use a 200 degree setting if your oven has it. A lot don't go that low, and 225 is pretty average. If that's the case, leave it in for maybe 20 minutes. When you remove it, some parts of the paint (heavier areas) may sill be volatile. You need to let the thing cool slowly so the vapors can release as it cools and hardens.
After that, you can have it or hand paint it yourself with whatever design ya like.
Couple of pointers:
There are a lot of really good quality spray paints out there. Most any quality brand enamel will work well if you take the time to cure (bake) it. Baking is not absolutely necessary, but adds trememdously to the durability.
One suggestion is to purchase automotive 'high heat' enamel. This is used to paint transmission differentials, engine blocks, etc. This bakes up very well and is much more durable than normal enamel, but not available is very many colors.
Enjoy, and if you can, post some pix of the end result.
Cheers,
Mike
