1 - 6 of 6 Posts
Cleavage Of The Tetons
Does anyone know if the XL lower assembly that came on the very rare SID dual crown (100mm travel) is the same size/compatible with 99-01' SID race lowers? Long shot here...
If you're refering to the stanchion width I believe Sids have always been 28mm from the very beginning so they should fit in. I don't know if the lower bolt attachments would be the same.
Discussion Starter · #3 ·
Not the stanchion width...
They are all 28mm. It is more the overall length of the lower slider, due to the fact that this was an 'XL' SID dual crown...
I don't think the length of the lowers matters. Sids are peculiar in that the lower castings are extremely short to save weight, hence the tons of exposed stanchion typical to them. Even in the ones you're taking about were considerably longer I doubt it would cause any sort of interference and full compression because there is so much room left to spare.
Discussion Starter · #5 ·
Thanks, Hecubus!
Is your handle from Kids in the hall, or what?
1 - 6 of 6 Posts
