Paddy wagon is a road SS/FG, whereas the San Jose is CX and $100 less. I will tell you this about the SJ, the wheels will need retruing after your first 1/2 lap around the block. Might or might not be the same for the Kona, but cannot be unexpected for inexpensive bikes. One more thing about the SJ rear wheel, you will need to pull the axle to change the FW because no FW tool will fit over the lock nut. Again, might or might no be true for the Kona but if they are spaced the same it could be. And the Bianchi is 100% chick designed. Oh yeah, the 06 SJ is FW only, not flip flop.
