121 - 140 of 185 Posts
aka DJ Papi
leeboy said:
hey bro... what a beauty!!! are we gonna see that in utah?! well.. hopefully i make it!!
Hey BRO!! If the baggage allowance weight will not be a problem and if I can sqeeze the Pack in a Trico case, I will bring her to Utah!! Otherwise, it will be the Spot. I will be attending Interbike and the THC. Try to make it bro!
When are you coming down this way? Lots of new trails in Sta Rosa!!!
Cheers :thumbsup:
Montana Stylie
All Mountain RFX
* Frame Size & Color: L RFX/ Ano Bronze / DHX Coil
* Fork: Fox Talas 36R
* Brakes: Magura Marta
* Rotors: 180/180
* Cranks: Shimano XT hollowtech w/ pressed in Phil bearings
* Front Derailleur: XT
* Rear Derailleur: SRAM X-9
* Pedals: Shimano 747
* Stem: FSA XC170 90mm
* Handlebar: Gravity Carbon
* Seatpost: Kalloy
* Saddle: WTB Rocket V
* Bottom Bracket: hollowtech w/ dr. phil
* Cassette: XT 11-34
* Headset: Chris King
* Grips: ODI lock on ruffian mx
* Front Tire: Kenda Nevegal DTC 2.35
* Front Rim: DT Swiss EX 5.1
* Front Hub: Hope Pro II
* Rear Tire: Kenda Nevegal DTC 2.35
* Rear Rim: DT Swiss EX 5.1
* Rear Hub/Skewer: Hope Pro II / Salsa stainless
* Weight: 32.25 lbs
No, that's not phonetic
The new BarnyMobile
* Frame Size & Color: Small '05 RFX, Gunmetal Gray PC
* Shock: DHX Air
* Fork: Zoke Z1 FR1 (with right spring pulled)
* Brakes: Magura Louise FR
* Rotors: 180/160
* Cranks: Shimano XT Hollowtech II, Truvativ bashring
* Chainguide Heim-3 Arm, MRP LRP roller
* Bottom Bracket: XT X-type
* Rear Derailleur: SRAM X.7
* Pedals: Shimano 959
* Stem: Ritchey WCS 90mm
* Handlebar: Easton Monkeylite Carbon XC
* Seatpost: Gravity Dropper 3" w/ remote
* Saddle: Terry Butterfly
* Grips: ODI Lock-on Yeti
* Front Tire: Varies: Nevegal 2.35, Nokian Core 2.3, Schwalbe King Jim
* Front Rim: Mavic X317 Disc
* Front Hub: King ISO 20mm
* Rear Tire: Varies: Kinetic 2.3, Nokian Core 2.3, Schwalbe King Jim
* Rear Rim: Mavic X317 Disc
* Rear Hub/Skewer: King Discotech / Salsa stainless
* Weight: 31.3 lbs
on a routine expedition
Time for an update. Lots has changed since I first posted this beast.
* Frame Size & Color: 2005 Large White 6 Pack / PUSH rockers / 5 Spot seat stay
* Rear Shock: DHX5.0 Coil with Push Factory Race System
* Fork: Rock Shox Lyric 2Step Air
* Brakes: Shimano Saint calipers/XT levers
* Blackspire Stinger chain tensioner
* Shifters: SRAM X0 Triggers
* Front Derailleur: Shimano XTR
* Rear Derailleur: SRAM X0 medium cage
* Pedals: Crank Bros. mallets / Wellgo MG1
* Stem: Thomson Elite 70mm
* Handlebar: Syncros BULK
* Seatpost: Thomson Elite
* Saddle: WTB Laser V
* Bottom Bracket: Shimano
* Cassette: SRAM PG990
* Chain: SRAM PC991
* Headset: Chris King Steelset / Hopey steering damper
* Grips: Pedro's Dice Vice Lock-on's
* Front Tyre: Schwalbe Big Betty
* Front Rim: DT 5.1D
* Front Hub: Hadley
* Rear Tyre: 2.35 Kenda Nevegal DTC
* Rear Rim: DT 5.1D
* Rear Hub: Hadley
* Seatclamp: Hope QR
* Weight: 33.75 lbs
RFX'ed
* Frame Size & Color: med 06 RFX black
* Shock: DHX Coil
* Fork: Lyric Coil
* Brakes: Hayes el camino
* Rotors: 8 F/R
* Cranks: FSA V Drive mega exo
* Bottom Bracket: Intergrated
* Front Derailleur: Sram X7
* Rear Derailleur: SRAM XO med cage
* Pedals: Candy SL
* Stem: Thompson X4 70 mm
* Handlebar: FSA Gravity Carbon
* Seatpost:Thompson elite
* Saddle: WTB Rocket V slt
* Cassette: Sram PG 990
* Grips: ODI Lock-on Rogue
* Front Tire: Kenda Blue groove 2.35
* Front Rim: DT EX 5.1
* Front Hub: Hadley thru axle
* Rear Tire: Kenda Nevagal 2.35
* Rear Rim: DT EX 5.1
* Rear Hub/Skewer: Hadley /hope QR
weighed in at 33lbs at local LBS today lighter than my heckler ,
3 "fiddy" for short
'06 5 Pack
* Frame Size & Color: '06 5 Pack, Black
* Fork: Lyrik Coil **Replace the Lyrik with an '06 66sl**
* Brakes: Juicy 7s with DangerBoy levers
* Cranks: Shimano XT with DangerBoy Bashguard and Blackspire Stinger Chainguide
* Rear Derailleur: Shimano XT
* Pedals: Time ATAC XS
* Stem: Thomson Elite **Thomson X4**
* Handlebar: Truvativ XR **Easton EA 70**
* Saddle: WTB Rocket V Lazer
* Bottom Bracket: Shimano External
* Cassette: Shimano XT
* Headset: Chris King **FSA Orbit Ext Pro Deep Cup**
* Grips: WTB **ourys that are not yet installed**
* Front Tire: WTB Timberwolf 2.35
* Front Rim: Mavic XM 321
* Front Hub/Skewer: Hope Pro 2
* Rear Tire: WTB Timberwolf 2.35
* Rear Rim: Mavic XM 321
* Rear Hub/Skewer: XT
'05 5-Pack
* Frame Size & Color: '05 5 Pack, White (sorry for the poor pics... taken from phone)
* Rear Shock: Cane Creek Double Barrel
* Fork: '06 Marz Z1 SL 20mm TA
* Brakes: Juicy 7s
* Front Derailleur: Shimano XT 761
* Rear Derailleur: Shimano XTR 960 GS
* Pedals: Shimano 540's
* Stem: Easton Mag (90mm)
* Handlebar: Answer Carbon riser
* Bottom Bracket: Race Face ext BB
* Grips: ODI
* Front Tire: Hutchinson UST
* Front Rim: Mavic XM 819
* Front Hub/Skewer: Chris King 20mm TA
* Rear Tire: Hutchinson UST
* Rear Rim: Mavic XM 819
* Rear Hub/Skewer: King Bolt-On
trail fairy
<table x:str="" style="border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" height="565" width="915"> [TR] [TD]TAs Turner RFX 06[/TD] [TD]Man this bike was made for me and I was made for her yeahhaaaaa
[/TD] [/TR] [TR] [TD][/TD] [TD]
[/TD] [/TR] [TR] [TD]* Frame Size & Color:[/TD] [TD]RFX 06 Med Ano Green (TNT)[/TD] [/TR] [TR] [TD]* Rear Shock: [/TD] [TD]Cane Creek CCDB 550lb spring (+ Ti 600lb)
[/TD] [/TR] [TR] [TD]* Fork: [/TD] [TD]Marzocchi 06 66 RC2X white 170mm
[/TD] [/TR] [TR] [TD]* Brakes: [/TD] [TD]Magura LouiseFRs 203fr/185r/Brakin rotors Hope Mono 4s Fr/r with brakin 203/185 rotors
[/TD] [/TR] [TR] [TD]* Cranks: [/TD] [TD]Race Face Atlas/ RF bash Guard[/TD] [/TR] [TR] [TD]* Front Derailleur: [/TD] [TD]Sram X Gen[/TD] [/TR] [TR] [TD]* Rear Derailleur: [/TD] [TD]Sram X9 07[/TD] [/TR] [TR] [TD]* Pedals: [/TD] [TD]Crank Bros Mallet Ms[/TD] [/TR] [TR] [TD]* Stem: [/TD] [TD]Diety 50mm White[/TD] [/TR] [TR] [TD]* Handlebar: [/TD] [TD]Diety White / 31.8mm[/TD] [/TR] [TR] [TD]* Seatpost: [/TD] [TD]Garvity Dropper 4inch / Homer approved[/TD] [/TR] [TR] [TD]* Saddle: [/TD] [TD]Wtb Pure V camo[/TD] [/TR] [TR] [TD]* Bottom Bracket: [/TD] [TD]RF Integrated with Diablous BB[/TD] [/TR] [TR] [TD]* Cassette: [/TD] [TD]Sram PC 990[/TD] [/TR] [TR] [TD]* Chain: [/TD] [TD]Sram PC 991[/TD] [/TR] [TR] [TD]* Headset: [/TD] [TD]Chris King gold no thread[/TD] [/TR] [TR] [TD]* Grips: [/TD] [TD]Oury Lock ons with Diety end caps[/TD] [/TR] [TR] [TD]* Front Tire: [/TD] [TD]Schwalbe Nobby Nics Big Betty's 3C Maxxis Minion 2.5, Kenda BG 2.5
[/TD] [/TR] [TR] [TD]* Front Rim: [/TD] [TD]Sun MTX Snow Camo 34mm 32 h[/TD] [/TR] [TR] [TD]* Front Hub:[/TD] [TD]Hadley 20mm Gold[/TD] [/TR] [TR] [TD]* Rear Tire: [/TD] [TD]Schwalbe Nobby Nics Big Betty's Maxxis Minion 2.35 kevlar bead
[/TD] [/TR] [TR] [TD]* Rear Rim:[/TD] [TD]Sun MTX Snow Camo 34mm 32 h[/TD] [/TR] [TR] [TD]* Rear Hub:[/TD] [TD]Hadley 36pt 10mm bolt through gold[/TD] [/TR] [TR] [TD]* Shifters: [/TD] [TD]Sram X0 Impulse shifters[/TD] [/TR] [TR] [TD]* Seatclamp:[/TD] [TD]Turner[/TD] [/TR] [TR] [TD]* Chainguide: [/TD] [TD]Blackspire Stinger[/TD] [/TR] [TR] [TD]* Cables[/TD] [TD]Nokons Black
[/TD] [/TR] [TR] [TD]* Weight: [/TD] [TD]36.65lbs feels and rides light impressive
[/TD] [/TR] [TR] [TD]* Future:[/TD] [TD]added recently
[/TD] [TD]
[/TD] [TD]
[/TD] [/TR] [/TABLE]
Frame Size & Color: '05 Large - Anodized grey
Rear Shock: Fox DHX 5 w/ 600lb spring
Fork: '05 RS Pike SL ('07 FOX 36 Talas RC2 soon)
Brakes (front): '05 Hayes HFX MAG 203mm
Brakes (rear): '05 Hayes HFX MAG 185mm
Cranks: Shimano Hone (FC-M600) 22-32-44, 175mm
Front Derailleur: SRAM X Gen
Rear Derailleur: 06 SRAM X.9 medium cage
Pedals: Azonic Xtension
Stem: FSA FR-230 - 1-1/8"x8°x90mmx31.8mm
Handlebar: Ritchey Rizer WCS/OS - 660/35/31,8mm
Seatpost: Thomson Elite SP-E113 - 27,2x410mm
Saddle: SDG Grand Prix CrMo black/black
Bottom Bracket: Shimano integrated
Cassette: '06 SRAM PG-990
Chain: SRAM PC991 Cross step
Headset: FSA Pig DH Pro Deep Cup 1 1/8" Black
Grips: ODI Ruffian Lock On Grips with Hope bar end
Front Tire: Tioga Factory DH Front 2,3
Front Rim: Rigida Disc Bull 36L
Front Hub/Skewer: Novatech DH41SB 20mm Bolt-on
Rear Tire: Tioga Factory DH Rear 2,3
Rear Rim: Rigida Disc Bull 36L
Rear Hub/Skewer: Novatech D362SB 10mm QR
Shifters: '06 SRAM X.9 Trigger shifters
Seatclamp: Hope QR
Chainguide: (e13 DRS soon)
Bicycle tire Bicycle frame Wheel Bicycle wheel rim Bicycle wheel
* Frame Size & Colour: 06 Large RFX, White powdercoat
* Fork: 07 Fox Van 36 RC2
* Shock: DHX Coil
* Brakes: Hayes El Camino, 8" front, 7" rear
* Cranks: LX with e13 bashguard
* Shifters: XT
* Front Derailleur: XTR
* Rear Derailleur: XTR
* Pedals: Time ATAC xe
* Stem: Gravity Lite 70mm
* Handlebar: WTB TXC 31.8
* Seatpost: Gravity Dropper 3 position
* Saddle: WTB
* Bottom Bracket: N/A
* Cassette: XT
* Grips: Lock-on
* Front Tire: Nev DTC 2.35
* Front Wheel: Mavic Crossmax XL
* Rear Tire: Nev DTC 2.35
* Rear Wheel: Mavic Crossmax XL
Just put it on the scale, today! 15.3Kg, thats almost 34lbs.
With maxxis 2.35 single-ply minions (8-900g)
Except for xc-tires, I don't think I can get it much lighter. Maybe a lighter saddle and bashguard, but thats not going to make a huge difference.
Thinking about a new fork for next year. Maybe Pike/Lyrik or All mountain SL/66sl1ata Not sure, though...
Amphibious Technologies
Update
* Frame Size & Colour: Small, Grey
* Fork: Rockshox Lyrik Coil U-turn - I really like this Fork! It performs better than the Pike, Van36 and TALAS 36.
* Shock: PUSH'd DHX - definitely the best shock I've ever had on this bike; much better than my CCDB and Avy Chubbie
* Brakes: Hope Mono 6Ti; Hope Mono M4 with Dangerboy levers
* Cranks: XT with Dangerboy Bashguard
* Shifters: SRAM XO Trigger
* Rear Derailleur: SRAM XO Blackbox
* Pedals: Shimano DX
* Stem: Thomson 70mm x 0 degrees
* Handlebar: Answer Protaper Oversize Carbon 1" rise
* Seatpost: Gravity Dropper 1" and 4" drop
* Saddle: Specialized Allias BG 130
* Cassette: XT
* Grips: Oury lock on
* Front Tire: 2.5 Maxxis High Roller UST Super Tacky
* Rear Tire: 2.35 Maxxis High Roller LUST
Reborn RFX
Hey folks; this one's been off the trails for a little while (family, work... usual guff). Summer holidays are here, so I've taken a couple of evenings to change its orig heavyset build to something a little lighter. I'm pretty keen on giving the whole 5-Pack thing a go, but this thing is pretty good in its current guise. About 33lb - a good five pounds lighter than it used to be.
* Frame Size & Color: Large, white 06 RFX, 5th Element Air shock
* Fork: RS Pike 426 Dual Air
* Brakes: Magura Louise FR (203/180mm rotors f/r)
* Cranks: RF Deus (will swap for Atlas)
* Front Derailleur: SRAM X-Gen
* Rear Derailleur: SRAM ESP 9.0 (sick of bending X9s...)
* Pedals: Shimano SPD 545s
* Stem: FSA 70mm/31.8mm
* Handlebar: FSA XC280
* Seatpost: Descenderpost
* Saddle: SDG S2000 (one of the first ones ever made!)
* Bottom Bracket: RF
* Cassette: SRAM 11-34t
* Headset: King (what else? :thumbsup: )
* Grips: Oury lock-on
* Front Tire: Maxxis Lopes 65A 2.3
* Front Rim: Sun S/track 32h
* Front Hub/Skewer: WTB Laser
* Rear Tire: Maxxis Lopes 70a 2.3
* Rear Rim: Sun S/track 36h
* Rear Hub/Skewer: Shimano XT
Picked up one of these '06 frames at Beyondbikes for their lowest closeout price, closeout '06 Z1 Light (Universal Cycles), and closeout '06 Magura brakes (eBay) and Dangerboy levers (Speedgoat). All the other parts were supplied by Chad at Red Barn Bicycles, who was a pleasure to deal with and hooked me up with some great deals. All in all the entire build ended up being cheaper that a new comparable Kona! Gotta love it ....
* Frame Size & Color: Medium Black
* Fork: '06 Z1 Light
* Brakes: '06 Magura Louise FR (190/180mm)
* Cranks: XT
* Bashguard: e13 supercharger
* Rear Derailleur: '07 X9
* Pedals: Wellgo magnesium flats
* Stem: Gravity Light 50mm
* Handlebar: Gravity Light
* Seatpost: Gravity Dropper (3 positions 0/-1/-4in)
* Saddle: WTB Pure V
* Cassette: SRAM 970
* Headset: Chris King NoThreadset
* Grips: Ody LockOn Rogue
* Front Tire: Kenda Nevy 2.35 StickE
* Front Rim: DT 5.1d
* Front Hub/Skewer: Hope Pro II
* Rear Tire: Kenda Nevy 2.35 StickE
* Rear Rim: DT 5.1d
Weight: 34lbs
Now I am going ridin'!
trail fairy
<table x:str="" style="border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" height="435" width="541">[TR][TD]TAs Turner RFX 06[/TD] [TD]updated & complete
[/TD] [TD]
[/TD] [/TR] [TR] [TD]* Brakes: [/TD] [TD]Hope Mono 4s 203fr/185r/Brakin rotors/braided hoses
[/TD] [/TR] [TR] [TD]* Cranks: [/TD] [TD]Race Face Atlas/ RF Diablous bash Guard[/TD] [/TR] [TR] [TD]* Front Derailleur: [/TD] [TD]Sram X Gen[/TD] [/TR] [TR] [TD]* Rear Derailleur: [/TD] [TD]Sram X9 07[/TD] [/TR] [TR] [TD]* Pedals: [/TD] [TD]Crank Bros Mallet Ms[/TD] [/TR] [TR] [TD]* Stem: [/TD] [TD]Diety 50mm White[/TD] [/TR] [TR] [TD]* Handlebar: [/TD] [TD]Diety White / 31.8mm[/TD] [/TR] [TR] [TD]* Seatpost: [/TD] [TD]Garvity Dropper 4inch / Homer approved[/TD] [/TR] [TR] [TD]* Saddle: [/TD] [TD]Wtb Pure V camo[/TD] [/TR] [TR] [TD]* Bottom Bracket: [/TD] [TD]RF Integrated with Diablous BB[/TD] [/TR] [TR] [TD]* Cassette: [/TD] [TD]Sram PC 990[/TD] [/TR] [TR] [TD]* Chain: [/TD] [TD]Sram PC 991[/TD] [/TR] [TR] [TD]* Headset: [/TD] [TD]Chris King gold no thread[/TD] [/TR] [TR] [TD]* Grips: [/TD] [TD]Oury Lock ons with Diety end caps[/TD] [/TR] [TR] [TD]* Front Tire: [/TD] [TD]Maxxis Minion 2.5 DHF 3C awesome front tire
[/TD] [/TR] [TR] [TD]* Front Rim: [/TD] [TD]Sun MTX Snow Camo 34mm 32 h[/TD] [/TR] [TR] [TD]* Front Hub:[/TD] [TD]Hadley 20mm Gold[/TD] [/TR] [TR] [TD]* Rear Tire: [/TD] [TD]Maxxis Minion 2.35/2.5 DHR 60a awesome[/TD] [/TR] [TR] [TD]* Rear Rim:[/TD] [TD]Sun MTX Snow Camo 34mm 32 h[/TD] [/TR] [TR] [TD]* Rear Hub:[/TD] [TD]Hadley 36pt 10mm bolt through gold[/TD] [/TR] [TR] [TD]* Shifters: [/TD] [TD]Sram X0 Impulse shifters[/TD] [/TR] [TR] [TD]* Seatclamp:[/TD] [TD]Turner[/TD] [/TR] [TR] [TD]* Chainguide: [/TD] [TD]Blackspire Stinger[/TD] [/TR] [TR] [TD]* Cables[/TD] [TD]Nokons Black
[/TD] [/TR] [TR] [TD]* Future:[/TD] [TD]can't see anything this is perfect for me
[/TD][/TR][/TABLE]
After a Month of watting to buy all the parts, here is what I got.
* Frame Size & Color: Large/White
* Rear Shock: Fox DHX 5 w/ 800lb spring
* Fork: Fox Van 36 RC2
* Brakes: Avid Codes
* Cranks: TruVativ Stylo 2.2 All Mountain
* Rear Derailleur: Sram X9
* Pedals: Shimano 647
* Stem: Syncros AM Stem
* Handlebar: Syntace Vector
* Seatpost: Thompson Elite 410MM
* Saddle: WTB Power V
* Bottom Bracket: TruVativ
* Chain: SRAM PC991
* Grips: Serfas
* Front Tire: 2.50 Nevegal
* Front Rim: Performance Locos
* Front Hub/Skewer: Performance Locos
* Rear Tire: 2.50 Nevegal
* Rear Rim: Performance Locos
* Rear Hub/Skewer: Performance Locos
* Shifters: Sram X.9 Triggers
* Weight: Unkown But I could guess it weights close to 40#s
G
Here is my ride
* Frame Size & Color: 06 Large Ano Black RFX w/ spot rockers
* Fork: Pike 454
* Brakes: Juicy Carbon
* Cranks: Atlas
* Front Derailleur: Xgen
* Rear Derailleur: X9
* Pedals: Shimano XTR
* Stem: Thompson X4 100mm
* Handlebar: Easton Monkeylite DH carbon
* Seatpost: Race Face
* Saddle: WTB Laser V team
* Bottom Bracket:
* Cassette: Sram
* Headset: Cane Creek S-3
* Grips: Oury
* Front Tire: Nevegal 2.35 DTC
* Front Rim: DT 5.1
* Front Hub/Skewer: DT 240
* Rear Tire: Nevegal 2.35 DTC
* Rear Rim: DT 5.1
* Rear Hub/Skewer: DT 240
