1 - 6 of 6 Posts
Looking for a new bike. Side walk tested an sb5 and sb130. Initial impressions at the time a month ago were that I liked the sb5 better I think because the frame is less stretched out I am 5’8 with shorter arms.
Based on the above I was interested in the sb5.5 can’t find a good deal on the sb5 anymore. I was drawn to the competitive cyclist deal on the x01 build which was $4.7k. Then I found out they will swap components and give you credit for parts you swap. I feel like I am heading down the slippery slope on and old frame. Now I am over $6k.
My build is below. Should I go with this build or revert back to the x01 stock build on competitive cyclist for under $5k. Alternatively I could do the gx sb130 and make a few upgrades. I don’t want to stretch the x01 sb130 build.
Thanks for your input.
Yeti SB5.5 Turq Series Raw
Fox Racing 36 Float 29 160 Grip 2 Boost
Industry Nine hydra enduros upgraded
Sram Code RSC Brakes
Sram X01 Eagle 12 Speed derailleur OE
Renthal Fatbar Carbon 35 20mm rise upgraded
Rental Apex Stem 50mm upgraded
Fox Factory Dropper Post 125mm upgraded
Ergon GE1 Evo Factory Grip upgraded
Ergon SM Pro Saddle upgraded
TruVativ Descendant Carbon Eagle DUB crankset Boost 170 / 32t
Cane Creek 40 series ZS 56/40 headset OE
Sram dub pressfit bottom bracket
Sram X01 Eagle 12 Speed Shifter OE
Sram X01 Eagle 12 Speed Chain OE X01 Eagle
Sram XG-1295 Eagle 12 Speed cassette OE 10-50t
Maxxis Minion DHF Wide Trail 3C 29 x 2.5. 3c upgraded
Maxxis Agressor EXO/TR 29 x 2.3 DC upgraded
SRAM centerline 200mm upgraded
Discussion Starter · #6 ·
Will most of these components carry over to a new frame in 3 years or so? Or will the industry have adapted new “standards” by then.
I guess the big thing that comes to mind is spending $1k on I-9 wheels with the new hydra hubs.
1 - 6 of 6 Posts
