I decided that it was a good time to totally overhaul my hardtail...so I took everything apart etc...rebuilt the rear derailuer, cleaned the front, striped the cables off to get ready to re run them, rebuilt the hubs even went as far as totally rebuilding the pedals...But then came the fork and the headset bearings....I took out the fork, and proceeded to clean and grease the top and bottom set of bearings...I cleaned off the steerer tube and then reinstalled the fork...problem is...now when i am turning the fork, it sounds as if there is dirt stuck in there...I thought I got it all...any tips on getting the dirt out? should I replace the bearings?? Also, the top bearings, which way should they be facing?? With the bearings up or down?? I thought they where facing down when I took the out, but now I am not so sure...
