This all started in April. I had a bunch of AM/FR components sitting around, and was after a deal on a 2007 El Guapo frame. At the time I didn't find the right number on a frame and couldn't move my 1x1, so I decided to postpone the purchase. Fastforward to July. Bob had a 2008 gold Guapo that I really couldn't resist, I sold my Surly and wrote a requiem, and I had exchanged my Van36 for a Talas36 (which I think belonged to Dominator13 - it was very well broken in!) I got the frame and fork one day after my toolbox had been shipped to WhistlerLand, and unable to wait, I did all of the building that I could with a torque wrench and a tube of grease.
Frame Impressions:
First of all, the gold color looks way better in real life than it does in photos. The welds look good - but not quite as good as they look on my 2007 MotoLite. All of the linkage hardware was torqued exactly to spec, which was very nice to see. The chainring bolt holding the derailleur hanger on snapped at about 45 in-lb, despite the fact that Titus recommends 80+/- 10 in-lb on their assembly document. I seem to remember the same thing happening when I built up my ML, so no big deal, any non-Titus chainring bolt seems able to carry the recommended torque. Frame weight for a large with seat clamp, hanger and shock was just under 8 lb.
The Build:
Getting the frame built after getting home from Whistler was my number one priority. It was mainly an XT build with 721 rims, Hayes Purple brakes, Atlas cranks (22-34-bashguard), a Fire FR 2.4 rear tire and a Nevegal Stick-E 2.35 front. I'd estimate the complete weight at 34-35 lb.
First Ride Impressions:
Confidence inspiring. Compared to the MotoLite The Guapo is much more solid and makes it easier to get the front wheel up. I was having some brake rub issues and my M750 low clamp front derailleur was useless for everything except making noise, but I still just wanted to jump off of anything I could find! It pedals extremely well even with ~50% sag (more on that later) and has descending manners that remind me of my DH bike. On more than a few descents I scared myself by carrying more speed and having worse brakes than I would with my ML.
The Common Complaints:
-BB Height: Doesn't seem to be an issue in forested/rooty terrain or while descending as long as the fork is set at 160mm. I only use the Talas for smooth climbs or road sections so no problems there. I did get quite a few pedal strikes while riding in Moab, but I can't really say the ML would have done better. If anything took getting used to it was the upright riding position - I smash my shoulders into trees way more than I hit my pedals on the ground!
-Cable Routing: I've got pretty long legs so I'm not really even coming close to hitting my legs on the cables or guides. The rear derailleur seems to be really hard to actuate, but I can't really understand why. I might try re-routing with teflon cables and continuous housing next season. Has anyone else experienced this?
-Tire Rub: With 50% sag and that big 2.4 tire I was hearing the buzz when bunny-hopping. Turned out the Nevegal was 1/4" shorter in tread height than the Fire, so switching the front and rear and ramping up the air pressure in the RP23 resolved most of that issue. I'm not sure, but I get the impression that the Guapo would be really well suited for a shock with bottom out control - it pedals so well at low pressure it's a shame to need to turn down the plush at the beginning of its travel. Still, I'm more than a little tempted to relocate the front derailleur housing guide that the tire rubs on...
-Department of Redundancy Department: Can a Guapo and a ML happily coexist? While building the gold one, I lightened the ML to about 28 lb. It feels like an absolute rocket in comparison, but after doing some time trials I found that the ML is only about 5 minutes faster on an hour long loop. Probably burnt 20% more calories in the process (I'd have to see what the HRM data says) but a Guapo will go XC if you stomp on it! Both bikes are great, I never know which one to take!
Frame Impressions:
The Build:
