For kids, or anyone? Personally, two years ago I needed to replace the chainring on my bike and took a flyer on an AB oval. I'll never go back to a round ring again. There's a very noticeable difference when the climbing gets steep, IMO.makes no difference.
Not sure if joking or idiot...Yay Biopace!
Absolutely does for Jnr,for anyone.
Maybe both, but not dumb enough to fall for the same thing twice.Not sure if joking or idiot...
I'm dropping down to a 30t chainring for my eagle so I don't wear out the bigger cogs. Is the sizing the same? 30t absolutely black oval = 30t everything else?Biopace =/ modern oval
Biopace oriented the oval to maximize the power stroke, which made the dead spot really dead and the overall power delivery was whack. Modern ovals are oriented to minimize the dead spot, and it works. When we got my wife a new bike last summer the first thing she said after the first ride was "This thing is great, but I need my oval ring back!" Plus, the AB direct-mount ovals are gorgeous. They're basically functional works of art.
I use usually use 2T more because im actually keeping more speed on tech climbs .. whereas without it tends to be more stop go .. I feel smoother on the oval and So going a bit faster and so I clear more obstacles with momentum ..(at least it feels that way)Yes, keep the sizing the same. Some people will tell you that you can move up a size but they're full of it. The gear inches stay the same. They don't magically make you fitter, they just make it easier to get past TDC when the climbing gets steep and techy and you're close to stalling out.
This is a good point. The anecdote about my wife aside, if you have a perfectly good round ring I wouldn't run out and drop $50 on an oval. If you're replacing a worn out ring or putting together a new build, give it a try for sure.So if your trails/kids are the same, I would say, don't bother running out and swapping for an oval ring.
On the other hand, if you are buying a different size ring anyway, you might want to try it, especially if your trails are loose and your kids attack's the steep climbs.
Hope this helps.
