You may need some chainring spacers, to move it away from the crank. This will also give you a better chainline!Just installed the chainring and it looks great.
But, I have a Shimano XT 2x10 crank and was running a SRAM PC1 chain and on the narrow part of the chainring, it's rubbing. I'm figuring I will need a narrower chain, but am not sure which type of chain I can should get 8, 9 or 10 speed.
Anyone else experience this problem and which chain worked best?
Thanks.
Where is it rubbing?Just installed the chainring and it looks great.
Thanks.
I've attached some picsWhere is it rubbing?
But can't beat the price $6.Get a real chain too, no matter what. That's not a good chain.
I'm hoping to avoid the spacers. The chainring already has a built in spacer.You may need some chainring spacers, to move it away from the crank. This will also give you a better chainline!
So its the 32t?I'm hoping to avoid the spacers. The chainring already has a built in spacer.
Yes, 32T. So I should be good with a 9 speed chain. Thanks!So its the 32t?
The PC1 is 1/8" and you'll need a 3/32" or narrower.
I would suggest a decent 8 speed chain from SRAM. They are stronger and cheaper than the 9 speed versions. That's all I run and have had great luck. I tried a PC1 once, never again!Yes, 32T. So I should be good with a 9 speed chain. Thanks!
The 8 speed is too wide for the gap between the ring and crank arm.I would suggest a decent 8 speed chain from SRAM. They are stronger and cheaper than the 9 speed versions. That's all I run and have had great luck. I tried a PC1 once, never again!
I'm not sure how close it is, but the 9 speed will be a little narrower and may give you more clearance.
The 34t front and a 17 rear would have a similar feel.I've got a Kona single speed I would like to put these sprockets on. Right now I'm geared 36-18 and would like to know what the biggest front sprocket is I can buy, then I can figure out what rear wheel sprocket I need. Will the rear sprockets fit my rear wheel? I just got this bike, I've been riding cruisers, not very familiar with this style bike. Thanks for any help, Dave.
