1 - 4 of 4 Posts
I have been researching and not certain what to purchase. Want to install Absolute Black oval chain ring in a 2019 Trek Fuel 9.8, drivetrain is all stock with 32 tooth SRAM Descrndant 7K Eagle Crank. Like to stick with 32 tooth oval.
Appears to be no offset on current round chain ring. AB only offers 3 or 6mm offset, I do not have much space to the chain stay so hate to add offset. Thought? Suggestions?
I would assume being a Trek, that it's a Boost frame, therefore, should be a 3mm offset. It's a direct mount, right? If there were no offset, the teeth on the ring would be exactly in line with the ring/crank junction. The ring would be absolutely flat.
1 - 4 of 4 Posts
