1 - 7 of 7 Posts
Help From The Big Guy
I switched from clipless to platforms recently-using Tioga Spyder pedals and Marizocchi Bomber shoes.
After long rides that have plenty of hills or riding thru lots of washes, the balls of my feet are hammered when I get back home.
I like the lighter weight of the Spyders but they're definitely smaller than regular platforms pedals.
The sole of the Marizocchi's seem plenty stiff enough.
Any ideas on whether I need to get a larger profile pedal to get rid of the pain or look for a shoe with a stiffer sole???
Thanks for the input.
It's about showing up.
You may not have broken in these shoes yet
High stress and damp might equal squirm. It is possible that you have not imbedded your feet into the insoles and shaped the upper to your foot. From the looks of the shoe there is a lot of settling to do. Try reworking the tension on the laces and rethink you sock choice.
Discussion Starter · #5 ·
BigSharks said:
I gotta ask- how do you like the platforms? I thought they looked cool as heck, but man, are they expensive...
I like the pedals a lot. Tioga includes a set of flat pins and pointed pins. I thought using the pointed pins might set me up for a bloodletting so I put in the flat pins. They work GOOD. The combo of the Stealth rubber on the Marizocchi and those pins are perfect.
Discussion Starter · #6 ·
The overall width of the Tioga pedals are much smaller than the base of the Marizocchi shoes. Its almost impossible to get the shoe (my foot) centered squarely on the pedal.
Those shoes with that particular pedal may not work.
Padded insoles?
Most cycling shoes seem to use thinly padded insoles if they have any at all. I have gotten used to upgrading my insoles immediately after buying new shoes. For me, the increase in comfort is dramatic. Dr. Scholl's makes some good ones, but there are many others sold to hikers that REI carries sometimes.
1 - 7 of 7 Posts
