no carbon MTB this year although the ultralight Scott Scale frame is the lightest but as stated many times such a bike will become heavier than by using the "old" scandium frames because of several parts that you need to use (cables,seatpost,f-derailleur...)
nevertheless - i still have a new 05 Scott Limited in my stable:
my new custom built 2005 CR1 Limited tips the scales at under 12 lbs. not bad considering the fact it still uses clincher wheels/tires. a nice tubular wheelset with tubular tires easily will bring it sub 5 kilos. as shown below it weighs 100g more as in the listing because of the CR420 wheels but they look cool...
my climbing speed went up 2 km/h (16 km/h instead of 14 on a climb) compared to my winterbike i used over the past months with the same wheels. i will have to check my position on the winterbike once again but if there's no difference it's the 2 kilos less weight that make for all the difference...
detailed specs here:
http://light-bikes.com/bikegallery/BikeListing.asp?id=558
Model: 05 Scott CR1 Limited "custom"
Bar Tape: Cinelli Cork 27
Bottle Cage: Tune Wassertraeger 7
Bottle Cage Bolts: 2 Aluminium 2
Bottom Bracket: Scandium ISIS (tuned) 105
Brake Levers: Campagnolo Record Ergopower (B-T-P Clamp) 326
Rear Brakes: Zero-Gravity (with shaved Kool Stop MTB pads) 177
Front Brakes: Zero Gravity (weight included above) 0
Cables: Tune Plastic housing,Jagwire wires 78
Cassette: Recon Aluminium 12-23 (incl. 4g Al-Lockring) 105
Chain: KMC X 10 SL 227
Crankset: 0
--Arms: Storck Powerarms Pro (172,5, ISIS,130mm) 313
--Crank Bolts: Scandium 27
--Ring bolts: FRM Aluminium 9
--Outer Ring: Specialite TA H�goa, 51 68
--Inner Ring: Specialite TA H�goa 38 25
Derlr (Front) Campagnolo Record Carbon (braze-on,Al-bolts) 66
Derlr (Rear) Campagnolo Record Titanium 10s 188
Fork: Look HSC 5 SL (220mm steerer) 278
Frame: 05 Scott CR1 Limited (Size M/54cm) 878
Handlebar: Schmolke carbon (40cm, reinforced for use with aero-bars) 169
Headset: FSA (semi integrated, no lower race needed on Look fork) 75
Headset Cap/Bolt: Extralite Expander plug, cap+bolt 17
Headset Spacer: Carbon 20mm 6
Pedals: Speedplay X-1 (tuned with B-T-P Al-plates) 132
Quick Releases: Heylight Aluminium TT Axles, shortened 20
Seat Binder: Extralite Ultra Clamp 12
Seat: Tune Concorde 45
Seatpost: New Ultimate 27,2/250=93g + USE adapter shim 31.6/65mm=17g 110
Shifters: Campagnolo Record Ergopower (weight see brakelevers) 0
Stem: Syntace f-99 (120mm, Ti-bolts) 102
Tire (Front) Continental Supersonic (700x20) 140
Tire (Rear): Continental Supersonic (700x20) 140
Tubes: Continental Supersonic 98
Wheelset (Front): 0
Wheelset (Rear): 0
Wheelset: custom FRM carbon / Amclassic CR350 1292
Misc Option: Ritchey WCS Rimtape 10
TOTAL: 5274 grams / 11.63 lbs
Crankset: 0
Wheelset (Front): 0
Wheelset (Rear): 0
