OK, this may be a two-part question. First, some background. I'm looking to build up a stouter set of wheels for my Moots Mooto-X YBB 29er. It has a Fox F29 fork on it and is a bit noodly on the trails with my current wheelset under my 190-200lb. geared-up weight. I've been shopping hubs for a custom wheel build and came across a set of takeoff DT Swiss built Specialized hubs off an '11 Stumpjumper (see the attached picture). The front hub is an OS 28 hub with a DT RWS.
My question(s): can you use this front hub with the OS 28 end caps on a standard fork (i.e. my standard QR Fox F29)? It looks like the end caps are huge and might interfere with the standard dropouts.; and if not, can you swap standard DT Swiss QR 9 end caps on this hub?
Thanks for any input from the Specialized experts!
