and here i'm , 6.1" tall looking na M size....lolHi swoop, interested to know if you test rode to come up with an xl sizing ?
I ask as I am 6’1” with a 33.5” inseam and the Orbea calculator puts me on a large. No chance to demo so trying to get as many opinions on sizing as possible before I decide on a size to order.
To be honest it was pretty easy. When I swapped to my XT 4-pots, it was the first time ever messing with Hydraulic brakes. Running the cable through the frame wasn't too difficult either. With the removable cable covers on inner chainstay and upper downtube, the openings are pretty easy to get the cables out of the frame, I just used a pick. Just start feeding the cables through the frame from the center toward each end. To install the olive and barbs and bleeding the system, I just watched a youtube video and all was simple.Anyone have any guidance on swapping brake systems on the Rallon? I just bought a new set of Magura MT7's and have never routed brakes internally before. Does anyone have any tips on doing this on the Rallon?
Thanks,Also make sure the existing cables aren't compatible and just leave them. Can't say for certain without looking it up but would wager the stock XT lines are the same as the 4 pots. It depends on the inner diameter but most are the same anymore. I simply left the lines and used Saint calipers.
I did the upper half of the frame first. Pulled the foam out of the frame. Pull as much of the new line out of the frame from the top leaving 6" of cable coming out of lower end. Slowly slide foam onto top half of cable. I inched it on kinda like a caterpillar. Once foam tube is on, slide back in to frame then install cable through chainstay.So I have an interesting update on Rallon internal routing.
I made an attempt to route the new brake line through the frame and actually found a foam tube that the previous brake line/shift cable was run through. It could just be something to stop cable rattling in the frame itself but im not sure. I was unsuccessful in routing the new line through this routing tube, but thought y'all should know. I've given up and am taking it into my local shop so they can deal with it. View attachment 1290257 View attachment 1290259
I'm running 29x2.6 Maxxis Minions, I'm sure 29x2.8 would fit, but would be tight clearance in the mud. I fit my 27.5x2.8 Minions on the bike to check BB height for another member....they fit easily but BB was way toooo low.Hey guys, I’m getting a bit bored with the bike and feel like experimenting. Can someone post the widest rim/tire combo they’ve safely run. I’m thinking of running Enve m735s with 2.5 f/r or The Santa Cruz 37s if there is enough clearance. Or 28s on the stick 30id rim.
Thx
