Anybody try a 27.5 rear wheel yet?
Seems like it would work good for this bike since the seat angle starts off steep.
Super keen to hear what you think of the shock.Got the ElevenSix in today and mounted up.
44mmWhat is the offset of your fork?
Have you considered a 550 spring? Also I would check out what size and shape the bump stop is on the Rallon specific Push coil shock and replicate it on the Fox. I’m waiting on my Rallon and my push coil so when they arrive I can comment further.Rallon owners. Is it possible that I prefer the dpx2 to the dhx2? I am 185 lbs w/ a 500lb spring. I am blowing through entire travel on aggressive southeast riding. Just seems the Dhx2 is either bottoming out on repeated medium size hits or I’m really struggling with the settings. Thoughts. Would appreciate setting suggestions.
DPX2 works really well. I'm 200 lbs full kit and I put 245 psi in the DPX2 and it has great mid stroke support and I'm not blowing through the travel on 2'-4' drops. My terrain in Colombia doesn't have anything really larger than that currently. I do run the DPX2 only in open mode and I dial in 4 clicks of Compression on the allen adjustmentRallon owners. Is it possible that I prefer the dpx2 to the dhx2? I am 185 lbs w/ a 500lb spring. I am blowing through entire travel on aggressive southeast riding. Just seems the Dhx2 is either bottoming out on repeated medium size hits or I’m really struggling with the settings. Thoughts. Would appreciate setting suggestions.
I think they are 180 front and back. According to this document from Orbea I can fit a 200mm rearWhat size rotors specd as stock?
Btw, competitivecyclist has shimano xt rotors for @$35
Mine came 203mm front and 180mm rear.What size rotors specd as stock?
