I have bought a 2nd hand Haro 24 VGF for my son. Overall the components and design seem quite good - with one exception. It routes both derailleur shift cables via the front of the downtube behind the front wheel, then they pass around the lower edge of the BB via a plastic guide. The cables are bare all the way through this route.
I'm concerned that shifting will suffer because dirt from the front wheel will cause wear and increased friction where they plastic guide is.
Obviously a fully sealed cable system is one solution, but I don't want to spend $70 on something like a Gore Rideon kit (it would cost almost as much as the bike cost)!
I have used Jagwire Ripcord on my MTB and it has sheathing and nosed ferrules that seal the cable run. However, I can't seen how I could use this around the BB. The Ripcord housing would end up being the load bearing surface for the cable around the BB and I wonder whether the cable may start to cut into the housing before too long.
Is there a replacement plastic guide that is sealed that the Jagwire could mate with?
What other cheap options exist to 'dirt proof' this type of cable routing? Or do we just have to be careful with cleaning after each ride?
