I'm looking into getting a good shock for my BMC Superstroke. It's a 150mm travel with a Fox RP2. I'm tired of screwing around with middle of the road forks, and recently deciced to pull the trigger on something high end.
I'm getting my RP2 pushed this month. I'm a big guy so Push is gonna set it up for my weight, approx 290lbs and dropping. As is I run about 260psi in it and pretty much run it with the pro pedal on most of the time.
I've been researching forks for quite a while, and the only one that strikes me is the Lyrik. Looking at the 2 step air model. It's the high end of the Lyrik line. But seeing as how I work at a shop, I can save a bit on it. Retail is like $1000-
What are your guys experiences with this fork?
Since I am a big guy would you suggest the coil version?
I really like the idea of the travel adjust on it, 115-160mm 2 step, and all of the other features seem sweet.
What is your take on RS's Floodgate lockout feature?
Any input would be greatly appreciated, on any of the Lyrik models and or their floodgate, or anything else you think I may need to know.
I've been a Manitou guy most of my life, but RS rocks too.
Thanx guys.
Thanx guys.
