Building on the success of its existing drivetrain specific product line, OneUp has launched two new Chain Guides.
First up is the Bash Guide. Developed with input from EWS World Champions Richie Rude and Jared Graves, this guide uses a reinforced Nylon bash mounted onto a back plate cut from 8mm thick 7075-T6 Aluminum. This allows it to survive massive hits, yet still only weigh 102 g (34T). MSRP is $79.
The new Bash Guide will be available in either Black or Green.
The new Bash Guide will be available in either Black or Green (click to enlarge).​
Affixed to the Yeti Cycles and Rocky Mountain Bicycle/Urge BP Rally Team, this chain guide has racked up more EWS stage wins than any other this year - not to mention winning the first two rounds of the series.
Specs
  • MSRP: $79 USD
  • Weight: 87g 28 -30T, 102g 32 -34T, 105g 36T
  • Capacity: 28 - 36T
  • Chainline: 5.5mm of adjustment
  • Mount: ISCG-05 only
  • Boost and Oval Compatible
  • Stainless Steel hardware
  • Construction: Back plate - 7075 aluminum, top guide and bash - Reinforced Nylon
  • Includes: 2 top guide pieces, 1x Black, 1x Green, and 3 size range Bashguards
The Low Direct Mount is simplicity at its finest.
The Low Direct Mount is simplicity at its finest (click to enlarge).​
The second new offering is the Low Direct Mount Guide (S3/E-Type), which was designed with weight conscious riders in mind. It weighs a mere 20 g and will retail for $42. Each one ships with three backplates, for the following sizes: 28-32, 32-34, and 36T.
Each One Up Low Direct Mount Guide ships with everything you see here.
Each One Up Low Direct Mount Guide ships with everything you see here (click to enlarge).​
Specs
  • MSRP: $32 USD
  • Weight: 20g
  • Capacity: 26 -36T front ring:
  • 5.5mm adjustment
  • Mount: Low Direct Mount S3/E -type only, Boost and Oval Compatible
  • Material: Reinforced Nylon
  • Includes: 2 top guide pieces, 1xBlack, 1x Green, and 3 size range backplates
Both chain guides are available now. For more information, visit www.oneupcomponents.com.
