1 - 3 of 3 Posts
Paper or plastic?
Okay, so I removed the cap and the bolt from the drive side, but I can't pull either crank. What am I missing?
Get your freak on!
Doesn't sound right...
You need the puller cap and bolt installed to remove them... install both of them to the correct torque then just stick your 8mm wrench in there and turn anti-clockwise...
Paper or plastic?
Discussion Starter · #3 ·
Thanks, it makes sense now. The bolt will just push the drive side crank out. I somehow could not figure it out last night...
1 - 3 of 3 Posts
