On One Rango Carbon 27.5 + SRAM GX1 Mountain Bike | Planet X
Could be good!
Just chainstay info in geo and seatpost diameter not correct.
Could be good!
Too bad the Portland store burned down : (On One Rango Carbon 27.5 + SRAM GX1 Mountain Bike | Planet X
Could be good!
Just chainstay info in geo not correct.
Good luck with that. Busy lads in my experience.Trying to press On One to give us some pictures of the bike with the 29+ setup.
Not sure if it will come with all 3 dropout sizes, but site says: Designed around a hot-swappable rear dropout system that can accommodate 650, 650+, 29er and 29+ ?Are the drop outs sliding or just fixed to certain sizes? I think that I want a 29+ single speed.
Good choice, just noticed today that the price dropped even more! What do you plan on using for wheels and tires? Keep your build progress posted here. ;DI've taken the plunge with the latest sale pricing.
£391.67 (ex VAT) = 52% off
£441.86 (ex VAT) shipped to USA
Even after currency conversion, the price is competitive with the no name eBay sellers.
A carbon Trek Stache on a budget?
My Dirt Wizards will finally have a home between Rango and the Fox 34 boost I'm getting ;-)
The first build will be 27.5+, using the Dirt Wizards that refused to fit my Banshee Phantom w/MRP Stage fork. I'm planning to build my 2nd wheelset using BHS hubs with either Spank Oozy Trail395+ or DT Swiss XM551's. Thought about going carbon rims, but currently leaning towards staying with aluminum. My first wheelset build used the Spanks, and they've been very good so far, and have the bling factor going for them. The XM551's are a little wider, but are a bit of an unknown for me.Good choice, just noticed today that the price dropped even more! What do you plan on using for wheels and tires? Keep your build progress posted here. ;D
Yeah, I have had both carbon and alum rims built up in the past few years. Good luck with 50mm carbons and even better experience with Dt XM481 rims. The 481's were laced to a 350 x 15mm front hub by my lbs. The Magic Mary tires set up tubeless so easy and have been leak proof all summer. I will have another set of these built and have also been looking at the 551's and hoping to see them in 29 size soon. Good luck with your build!The first build will be 27.5+, using the Dirt Wizards that refused to fit my Banshee Phantom w/MRP Stage fork. I'm planning to build my 2nd wheelset using BHS hubs with either Spank Oozy Trail395+ or DT Swiss XM551's. Thought about going carbon rims, but currently leaning towards staying with aluminum. My first wheelset build used the Spanks, and they've been very good so far, and have the bling factor going for them. The XM551's are a little wider, but are a bit of an unknown for me.
I just paid $576, so the difference is only $50, and I'm fine with that.CS-496 can be purchased for about $525 delivered to US (frame + delivery + paypal fee). So about $100 less than On-One.
According to the Planet X website, the Rango is is approved/designed for 130-160mm travel forks, with 509mm A2C being used for the geometry calculations.Seems like the Rango/CS-496 are designed more to a 120mm travel fork (at 27.5+) and the others are designed more to a 140mm fork (at 27.5+).
I wasn't criticizing anyone's purchase. Just letting folks know their options. Current price under their "cake number sale" is $550 + $70 shipping, hence my $100 reference.I just paid $576, so the difference is only $50, and I'm fine with that.
This reflects the lack of attention to details that I find typical of On-One / Planet X. They do say 130-160 in their frame spec, but that is inconsistent with the 506mm C2A they show in the geo chart. Or look at their complete bike build for this frame, which uses a 120mm fork. So either their chart is wrong, or their own complete bike is built outside the recommended range.According to the Planet X website, the Rango is is approved/designed for 130-160mm travel forks, with 509mm A2C being used for the geometry calculations.
No offense taken - just pointing out there's a better deal to be had if you pay in GBP and let either PayPal or your credit card handle the currency conversion.I wasn't criticizing anyone's purchase. Just letting folks know their options. Current price under their "cake number sale" is $550 + $70 shipping, hence my $100 reference.
InertiaMan;12946699This reflects the lack of attention to details that I find typical of On-One / Planet X./QUOTE said:Isn't inconsistency the name of the game when it comes to Chinese carbon frames? You can see what appears to be the same frame on several sites with different geometry numbers, so this isn't exactly unheard of. Even the big companies screw up the geometry table now and then. I've done the same geometry calculations, and would agree that 130-140mm is probably going to be the sweet spot for most. 160 does seem excessive for this frame, and I'm not going to comment on their own build spec, as it's likely kitted out as it is to hit a certain price point.
Good call. I went back and checked their effective exchange rates and they are obscene: .71GBP/$ from On-One, versus .77GBP/$ from Paypal, and .79GBP/$ current wholesale rate. That is WAY worse than the rates I've typically seen from UK parts suppliers I've used. I've never ordered from On-One, but if I do, I'll certainly not let them handle the exchange. Charging 10% above the wholesale rate is robbery.No offense taken - just pointing out there's a better deal to be had if you pay in GBP and let either PayPal or your credit card handle the currency conversion.
I wasn't suggesting the Chinese sources were more consistent. Rather, I view On-One as sometimes being little more than a veneer on top of generic Asian imports; more akin to a Performance Bike and their house brands (albeit with far more diverse offerings) than a "true" bike brand that outsources production but fully retains their own robust design and engineering. I'm not suggesting there aren't some good quality (and high value) bikes available from them, just that they often seem far less thought-out than a "true" bike brand.Isn't inconsistency the name of the game when it comes to Chinese carbon frames? You can see what appears to be the same frame on several sites with different geometry numbers, so this isn't exactly unheard of.
