Thank you for that, I saw your thread from months ago but there was never any info regarding a definitive answer... looks like disc brakes are the only way now-a-days.p nut said:No, no removeable v brake bosses, although the site still indicates it does.
yes but if he were to install the ring in the middle(center position of the spider) and the cog between the spacers would the chain line be off?alexrex20 said:he mounted the ring to the outside of the spider.
I assume the reason Nuck asked about moving the chainline inboard is the farther from the bike's centerline the chainline rests, the more torque is applied to frame deflection when pedaling. That is to say the more leverage the rider will put into bending the chainstays whenever hammering the pedals.Mudsimus said:I tried mounting the chainring on the inside and moving the cog. But the chain line was a little off. Its a perfect straight line as it is now.
