Im trying to identify the the front fork on the wife's old Specialized Rockhopper FS (guessing a late 90's). I cannot locate a serial number anywhere on the fork. It is oil filled (leaking oil and reason for this post). It has the smooth plastic caps on top of each shock, non adjustable preload. There are snap rings under the boots that appear to hold the shock tubes in place. I am thinking it is not serviceable. If it helps it is a threaded steer tube.
If I end up having to replace it, what should I get? Looking to get something inexpensive as she mainly just rides smooth trails.
