I'm trying to ID a frame better. Its an early 90s rocky mountain, serial # I91020404, I think its a Fusion but I don't remember Ishiwata (whose tubing they used on Fusions at the time) offering an ovalized down tube the same way Tange Prestige Concept tubing was ovalized, as this frame has on it. Its fastback stays, and the seattube doesn't extend way up so its not a Blizzard, and the dropouts don't say Ritchey, which discounts it being a Hammer. Its onto its umpteenth repaint but when I stirpped the last paint off I found a dark purple base color on it, under several layers of black paint. Oh, its 1 1/8" headset sized, but also has U-brake studs on the seatstays, and its got the standard seattube/toptube lug that most steel rocky frames of the period had. The toptube does slope somewhat, and the headtube is about 6.5" long which is typical for a 20" frame from the company at that time. Frame weight is about 5.5 pounds with paint, which is somewhat lighter than a fusion should be in that size as well. Its tig-welded, which discounts it being a thunderbolt. And the cable housing guides for the derailleurs route down the downtube (my 91 stratos is the same that way, but 90-91 hammer's had all top-routed cables, 89s did not but they were also sized for 1" headsets).
Anyone with any ideas?
