Can find a lot about the V2 and if it is lighter than the old version. Anyone run the V2 and recomend over the original?
So what is the trick?. My rears, and now fronts have leaked. The rear was retaped with masses of tape. The lbs did it so i am not sure how. The lining is bulging out the cutouts to a scary degree, and the leaks develop everywhere.V2 is a little lighter but more of a pain to setup tubeless, as in the taping procedure. The cutouts are HUGE, very wide near the bead shelf. I have done 8 of them, and you have to take care with taping.
First three leaked, till i modified my taping process. Since then, they have worked excellent.
Regarding strength, they are the same as v1. I bent a v2 on the first ride, same as v1...
your LBS did it? you need to take control yourself. my LBS had issues sealing one of my wheelsets a while back, so I had to figure it out myself.So what is the trick?. My rears, and now fronts have leaked. The rear was retaped with masses of tape. The lbs did it so i am not sure how. The lining is bulging out the cutouts to a scary degree, and the leaks develop everywhere.
the only thing i would add is when the rim strips are new, i leave a tube in it overnight before i start my taping process. as mentioned before, the v2 cutouts are much larger then before right next to the bead shelf. most of the tubeless leakage i have seen is in this area.**** can the gorilla tape and use some Sun Ringle, Kapton, Zip or some other tape that is less permeable than gorilla and is full width to run up the side of the rim into the bead seats. Clean the rim with some alcohol ..
