1 - 2 of 2 Posts
Hey all,
I've got a Cannondale F900SX with what I understand is an older Lefty fork (2001 or 2002 I think).
As best as I can tell the fork no longer holds air. If I pump it up to a comfortable level (pretty high - I weight 200lbs) it gets very spongy after a few days and will compress significantly when I put weight on it. When I attach the pump it shows 30-50psi in the fork - far less than I had pumped it up to.
I've done a search about rebuilding Lefties but it seems that most of the post and how-tos are for new style forks, not my older one. I'd like to do it myself.
Any help is much appreciated!
-RW
Hybrid Leftys aren't real
Older Lefties were more tool intensive than the new ones. You need new air piston seals, and most likely a full go through wouldn't hurt. If you want to spend $100+ in tools, many that will only work with that fork, go for it, but I'd suggest finding a competent shop, and let them handle it. Not saying you can't do it, but time, money and hassle factors suggest an alternate course :cool:
1 - 2 of 2 Posts
