Yeah sorry, I wanted to post links to the specs but I am too new to the forums to be able to post links.
Judging by pictures, the wear on the tires and what the seller tells me, the 2005 Rampage has been used very little.
I will try to post the full specs here and hopefully it comes out readable:
All specs were taken from BikePedia.
2009 Norco Bigfoot:
Bicycle Type Mountain bike, front suspension
MSRP (new) Unspecified
Weight 35lbs
Sizes 12.5", 15", 17", 18.5", 20", 22"
Colors Black, Coffee Tan
Item ID 16785
-----Frame & Fork----
Frame Construction TIG-welded
Frame Tubing Material Hydraformed Aluminum
Fork Brand & Model Marzocchi DJ 3, 120mm travel
Fork Material Single
Rear Shock Not applicable
----Components----
Component Group SRAM Mix
Brakeset Avid Juicy 3 w/ 7" Rotor front/Avid Juicy 3 w/ 6" rotor rear brakes, Avid Juicy 3 levers
Shift Levers SRAM X.5
Front Derailleur Shimano Acera
Rear Derailleur SRAM X.5
Crankset Truvativ Ruktion, 24/34 teeth
Pedals Flat alloy
Bottom Bracket TruVativ Howitzer
BB Shell Width Unspecified
Rear Cogs 9-speed, 11 - 32 teeth
Chain KMC Z9000, 1/2 x 3/32"
Seatpost Alloy, 27.2mm diameter
Saddle Norco Shore
Handlebar TruVativ Hussefelt
Handlebar Stem TruVativ Hussefelt
Headset 1 1/8" threadless FSA TH-855
----Wheels----
Hubs KT disc
Rims WTB Dual Duty, 32-hole
Tires 26 x 2.35" Kenda Nevegal Stick E Rubber
Spoke Brand Unspecified
Spoke Nipples Unspecified
2005 Norco Rampage:
MSRP (new) $1,699.00
Weight 39lbs
Sizes Small, medium, large
Colors Red
Item ID 93971
Frame Tubing Material 6061 T6 aluminum
Fork Brand & Model Marzocchi Z-1 FR3 , 150mm travel
Fork Material Aluminum/magnesium, single crown
----Components----
Component Group Mountain Mix
Brakeset Hayes HFX-9 Hydraulic Disc brakes, Hayes HFX-9 Hydraulic Disc front/Hayes HFX-9 Hydraulic rear levers
Shift Levers Shimano Alivio RapidFire
Front Derailleur Shimano Alivio, top-pull/clamp-on 35.0mm
Rear Derailleur Shimano Deore LX
Crankset TruVativ Hussefelt w/ bashguard, 22/32 teeth
Pedals TruVativ Hussefelt
Bottom Bracket TruVativ ISIS DH
Rear Cogs 8-speed, 11 - 32 teeth
Chain KMC Z72, 1/2 x 3/32"
Seatpost TruVativ XR Dual Clamp, 30.0mm diameter
Saddle Titec Berserker
Handlebar Titec El Norte
Handlebar Stem Titec El Norte
Headset 1 1/8" threadless FSA Deepcup
----Wheels----
Hubs Front: Novatec 20mm, Rear: Shimano Deore Disc
Rims Sun Rims Single Track, 32-hole
Tires Front: 26 x 2.30" Kenda Blue Groove, Rear: 26 x 2.30" Kenda Nevegal
Spoke Brand DT Swiss stainless steel, 14ga. (2.0mm) straight gauge
Spoke Nipples Brass nipples
Based on what I have read, the Shimano Alivio stuff on the rampage is better then the Shimano Acera stuff on the bigfoot. I think Hayes HFX-9 are also higher-end than Avid Juicy 3 but I have seen mixed opinions on the two.
