To expand on the other thread about older suspension bike/fork setups, I thought I'd write this up... in the Feb 1992 Bicycling (an interesting issue to be sure as they had a Univega Team Shockblok featured also and its obvious now that it was the Boulder Defiant frame with new decals/paint) tested the five most popular spec'ed suspension forks of the model year... Scott Unishocks (the original white version that Ruthie Mathes won her world '91 XC title on) with 2" of travel, Answer Manitou 1 with 1.6" of travel, Trek DDS3 with 1.8", Specialized Futureshock at 1.75", and Rockshox Mag-20 at 1.84". They built this machine called the MONSTER that'd record the G forces transmitted to the rider at the handlebars by the fork over a trail ride (same rider/tire pressure, same line around the course, same speed), a 3-bump test (3 2x4s 20' apart in a parking lot, 12mph speed), and a 6" curb at 5mph. All forks were run at factory recommended setups and the ones with damping adjustments were tested across the full range to factor into the numbers. They also tested a conventional steel rigid fork (curved blades) to compare against.
- The rigid fork averaged 5Gs on the trail, 4.5 on the 3bump and 7.7 on the curb impact.
- The Mag-20 was 4.1, 4.0 and 4.3 respectively
- The Futureshock was 3.1, 3.7 and 3.3 respectively
- The DDS3 was 3.3, 4.1 and 2.9 respectively
- The Manitou was 3.5, 3.9, and 2.9 respectively
- The Unishocks was 3.2, 3.8, and 4.8 respectively
In other words, the Mag-20 was beaten in every category and by every fork EXCEPT the unishocks in the curb impact, and the dds3 in the 3-bump test. Yet somehow it was considered the top fork of the year by most magazines. Makes you wonder how many magazine editor bar tabs it cost paul turner to pull that one off.
In August 1993 they did another fork test, this time with 10 forks, but this series they changed the MONSTER tests to using a series of wood blocks on a flywheel and the bike with the forks was fixed to it and preloaded to simulate a 150 pound rider. They used 1", 2" and 3" wood blocks and recorded the G-forces the suspension fork transmitted to the bars when it encountered the different size blocks. They also measured the fork travel for each size impact. I'll try and get the g-forces right, they used these goofy bar graphs in this article, and didn't print the actual numbers. Again they tested an oversized unicrown rigid fork also, and got 3G for the 1", 7G for the 2", and the 3" there was no figure because the fork kept bouncing erratically.
- Rockshox Mag-21 scored 1.5G/11mm for the 1", 3.9G/15mm for 2" and 4G/20mm for 3" blocks.
- Rockshox Quadra scored 2.3G/6mm, 3G/19mm, 4G/28mm
- Trek Mogul Black Diamond scored 2.5G/8mm, 5G/16mm, 7.5G/24mm (now that's consistent)
- Manitou 2 scored 2.5G/7mm, 5.3G/19mm, 7.8G/25mm
- Future Shock Adjustable scored 3G/14mm, 6.8G/21mm and ?!?G/31mm (they didn't list a G figure for some reason for the 3", maybe it went off their chart that only went up to 8G)
- Schwinn Paiolo scored 2.5G/6mm, 6.7G/16mm, 6G/17mm (go figure, bigger impact, 1mm more travel, and lower G score)
- Tange Struts scored 2G/10mm, 2.5G/18mm, 7.5G/26mm
- SR DuoTrack scored 2.3G/7mm, 5G/27mm, 7G/28mm
- Marzocchi XC400 scored 2.5G/13mm, 5G/18mm, 7.5G/25mm
- Scott Unishocks LF 2.5G/6mm, 5.3G/12mm, 6.6G/17mm
Now later on in the same issue it has the included Mountain Bike magazine (this was back before MB split off into their own seperate publication) section where they tested that Unishocks LF at greater length and they listed for a 2" bump on the monster (but not exactly what sort of 2" bump they used) a score of 3.3G on setting 1 (of the compression lockout dials) for a Mag-21, 3.3G for a Manitou 2, and 3.5G for the Unishocks LF. So whatever the bump was this time, it wasn't the same as for the test series bicycling ran in the same issue.
Skip ahead another year to October 1994 and they test 10 more forks with the same 1", 2" and 3" bumps as the 1993 test setup. Except this time they don't tell us how much the forks actually compressed and they didn't actually test either the girvin vector nor the Amp F-1 as neither they claimed would fit their apparatus on account of the rearward extending linkages. This is amusing as the kind of square edge bumps they tested with coming head on at the wheel is EXACTLY the sort of impact these linkage forks excell at, and beat telescopic forks hands down with. So I suspect they didn't print the test numbers because neither company spent as much on advertising as Rockshox and Manitou did, and they couldn't risk printing how much better these forks were for the bumps they were testing the forks against. Who'd buy a Manitou 3 if the Girvin or Amp is shown to score 1/2 as many G's for an identical bump (especially when the Amp was $30 cheaper and only 1/10th of a pound heavier). Anyways, the test numbers were...
- SR/Suntour Duotrack 9001 2G / 4.8G / 5.2G
- Rockshox Quadra 10 2.8G / 4.2G / 7.4G
- Tange Pro Struts 1.9G / 5.2G / 5.3G
- Specialized FutureShock Adjustable 1.5G / 3G / 5.3G
- Marzocchi XC500 4G / 4.7G / 6.9G
- Manitou 3 1.6G / 3.7G / 3.8G (best in test they claimed)
- Scott Unishocks LFR 2.6G / 3.2G / 4.5G
- Rockshox Mag-21 SL Ti 1.9G / 5G / 6G
Edit : As i read thru old issues i find Mountain Bike tested the original Mongoose/Amp Research Amplifier fork in their April 1993 issue and gave a 4.0G figure for a 2" bump, with a Mag-21 at 3.3G and a Halson Inversion at 3.5G for comparison. So how come Mountain Bike managed to test the linkage fork on the MONSTER but Bicycling magazine couldn't ?!?
