Kind of posted this in drivetrain but only singlespeed folks would care about this problem.
When my driveside pedal is fully forward my chain is loose to the point where I will get chain drop. When the pedal is fully back then the chain is too tight like stiff tight. I loosened the chainring to reinstall it thinking that it wasn't centered but even with a loose chainring it happens in the same position. My monocog is a dinglespeed so I put the chain on the other set of gears. Same problem. I rotated the rear axle. Same problem.
Does that sound like a bent bottom bracket? Since it happens all the time with the pedals in the same position this isn't a problem with my rear axle/hub/dropout correct? How do I troubleshoot this problem to find what is bent?
I am 200 lbs and do sometimes get a little bunnyhop on.
