Here she is. 5" travel in back, almost 4" in front. To get the chain to clear the tire comfortably I had to skip the granny ring. I also left the 3 smallest cogs off the cassette and spaced the remaining spider-mounted cogs out using some cassette spacers. This gives me a 6 x 1. I want to ditch the 32t front for a 30t to drop the gearing a little, but this is what I had laying around for now. I used a 118mm e-type bb with a bunch of spacers on the drive side to give me clearance. There is no problem with rub in any gear, but I am having some problems setting the low der stop so far from it's normal position. I need to think about that issue. Amazingly enough, the tire just barely buzzes the front der cable stop at bottomout. I thought it would slam into the seat tube. I turned the BO adjuster in and bumped the psi by a few for buzz-protection.
The rear end is a stock Turner 6-Pack triangle mated to my 5-Spot front. It clears the Large Marge/Nokian 3.0 nicely.
