I have a 2005 drop off triple. the rebound on it is very fast and i wanted to make it slower by putting in thicker oil. could someone please explain step by step how to change the oil?
thanks
thanks
if changing the oil in a 05 is anything like the 04 its pretty simple. deflate the air pressure so u dont spray oil everywhere. if you are changing the oil with the fork on the bike you should remove your caliper and wheel so they dont get in they way or contamination of pads. unscrew the 2 little silver caps on the bottom of the fork just enough that oil starts to leak out. you might want to get a cup or something to catch the oil. then unscrew. compress the fork a couple times to make sure there is no existing oil left in the fork. you should be able to compress the fork so the lower crowns are very close to the seals in the lowers.screw those 2 silver caps on the bottom of the fork back on and unscrew the 2 caps ontop of the fork(where u fill with air) fill the fork with the desired amount of oil, screw the caps back on and check over the fork to make sure everything is tight. compress the fork a couple times, then fill back up with air. when i did it i completely removed the 2 bottom caps on the lowers and it was very very hard to get them to catch on the threads again. the caps actaully didnt catch one time and when i compressed the fork they flew out and i had to re-do the whole thign again. save urself the stress and trouble take your time man.Amazing Larry104 said:I have a 2005 drop off triple. the rebound on it is very fast and i wanted to make it slower by putting in thicker oil. could someone please explain step by step how to change the oil?
thanks
Dropoffs dont have rebound adjustment.SHIVER ME TIMBERS said:saving time solution........why don't you just slow down the rebound...that would make a big difference...have one of your friends or someone who knows adjust your fork to your weight....you are probably to small to need to go to thicker fork oil...all you guys look skinny
They both end up doing the same thing. I just pop off the caps, take the spring out, turn it upside down and drain. And then compress it a few times to get it all. Then I'll cycle some fresh oil through to remove any build-up before filling it up with new oil.Amazing Larry104 said:actually i weigh like 175 so i bottom it out a lot even with a lot of air, so it would be good if it was harder to compress. which method would be better?- taking off the caps and flipping it upside down or just draining it out the bottom?
oops...didn't see thatMarzocchiFork said:Dropoffs dont have rebound adjustment.
you weight the same as me use 10wt oil 250ccAmazing Larry104 said:the marzocchi oil level tabel doesnt have DOT. how much should i put in?
im thinkign yes, but dont take my word for itZonk0u said:is this process pretty much the same for the 05 single crown drop off?
